06-03-2017, 12:48 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | is supported by cm2 read/write ? honor 5x Model: KIW-L21 Brand: HONOR Device: HNKIW-Q Platform: msm8916 is supported by infinity read/write ? please help how can do this? need testpoint? or with edl can do it? |
06-06-2017, 10:28 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | try methods from post below also try via recovery (adb reboot edl) http://forum.gsmhosting.com/vbb/12517713-post3.html |
06-06-2017, 12:15 | #7 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | finally read from ok phone but have this error Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.13 Emergency driver NOT found, make sure it installed! Download and install from support area following file : >> InfinityBox_Update_CM2QLM_Drivers_v1.xx.rar Install it, go to /CM2QLM/Drivers/ and install ALL packages inside >> If device detected by PC, but not detected by SW : > 1. Open device manager, find in PORTS section "9008" device > 2. Change (update) driver to Emergency (or) QHSUSB_BULK Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : HONOR Device Manufact.: unknown Device Model : msm8916_64 Device CPU : MSM8916 Device IntName : msm8916_64 Device Version : 5.1.1 CU_SWVer : unknown Device Compile : 12/10/2015 02:41:55 ب.ظ Device ExtInfo : MSM8916 for arm64 Load Ok! Operation : Flash [ v1.13 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 28 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : hyp.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : misc.img Flashing : NON-HLOS.bin Flashing : persist.img Flashing : boot.img Flashing : recovery.img Flashing : rec2.img Flashing : cache.img Flashing : cust.img Flashing : system.img Flashing : userdata.img ProgStart : Parsed value exceeds size of partition in sectors Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.13 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 28 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.13 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 28 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : hyp.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : misc.img Flashing : NON-HLOS.bin Flashing : persist.img Flashing : boot.img Flashing : recovery.img Flashing : rec2.img Flashing : cache.img Flashing : cust.img Flashing : system.img Flashing : userdata.img ProgStart : Parsed value exceeds size of partition in sectors Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash [ v1.13 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Flash [ v1.13 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 28 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : hyp.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : misc.img Flashing : NON-HLOS.bin Flashing : persist.img Flashing : boot.img Flashing : recovery.img Flashing : rec2.img Flashing : cache.img Flashing : cust.img Flashing : system.img Flashing : userdata.img ProgStart : Parsed value exceeds size of partition in sectors Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
06-06-2017, 12:17 | #8 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 05466C44 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93 ID_BLOCK_L : 1D70DE7162ED5DD6EBCA8F444EA1BF9C Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
