05-17-2007, 18:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 305197 Status: Offline Thanks Meter: 8 | W370 Unlock Procedure Please Help!!! I'm not really worried about repairing this phone as I can wait till later but would like to attempt another phone but need to know the proper way to flash the phone. What phone do I select in what tool? What files should be loaded on the phone? |
05-17-2007, 18:52 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, It was not so good idea to flash phone that you don't see in supported models list. At first you need to make flash backup (read flash) from new phone and send backup file (and "operation.log" file) to [email protected] to check. |
05-17-2007, 19:46 | #3 (permalink) |
Member: 305197 Status: Offline Thanks Meter: 8 | It is the same as the W375, they use the same firmware, I will get a fresh phone and send those files but my question was what would normally be done on a W375 because it will be the same procedure on the W370. Also it is a Tracfone. What should be flashed just the firmware and the language pack? I know on the C261 I was told not to flash the flex file but I could never get it working properly and then someone pointed me to a flex file and it worked every time after that. |
05-18-2007, 21:57 | #6 (permalink) |
Member: 305197 Status: Offline Thanks Meter: 8 | Still stuck please help and thanks so far!!! :) Ok so I put back the original tracfone W370 flash, lp, and flex from the support area and phone will not turn on at all afterwards tried several times. Then I flashed with w375 files set: main + lp + flex (retail flex, NOT locked). from support area. Phone then booted and formatted fmgr etc. Then stated Phone is Hacked:68 and went into constant reboot. Then I flashed the W370 tracfone flex with W375 flash and lp and phone formatted fmgr and then booted to subsidy code screen. I tried the SP-Unlock with the tracfone flex but this did not work as it stated phone not locked. This is all done from the C261 area of Moto01 correct? |
05-21-2007, 23:10 | #9 (permalink) |
Member: 305197 Status: Offline Thanks Meter: 8 | Its the normal T191 cable that you use on the C139 C155 C261 and several other Motorola models. I'm still waiting for Infinity to send me a modified eeprom file to test out the unlocking procedure. |
05-29-2007, 20:51 | #11 (permalink) |
Member: 305197 Status: Offline Thanks Meter: 8 | Not sure what specific Compal specific tool you are asking about. On another note Infinity I emailed a new full flash from a non modified W370 phone please update the support area with the new flash because the one on site is corrupt. |
05-30-2007, 18:59 | #14 (permalink) |
Member: 305197 Status: Offline Thanks Meter: 8 | Thanks for the response. I have been reading all over the forum about the unlock procedure with this phone and at this time it appears that the Smart Clip box has a feature to fix the "Phone is Hacked:68" error after flash which is performed with a repair eeprom option. Is this feature going to be available with the Infinity Box? |
P990 unlock procedure please | bowei | SETool2 | 11 | 04-05-2009 11:07 |
again e570 unlock procedure please!?! | sale | Easy-Unlocker | 1 | 12-12-2008 15:22 |
my x6-2 unlock procedure please help | kasper17 | SAGEM JTAG UNLOCKER | 1 | 11-04-2008 08:24 |
sharp 703 ver.2006 unlocking procedure pls... help | dsaxor | Sharp | 3 | 06-02-2006 14:22 |
MW3027 unlocking procedure please? | sepia | Infineon C16X M51 & ARM7 M52 BASED | 4 | 01-18-2005 15:04 |
