susessfully unlock vodafone125 counter block hi frand today i sucsessfully unlock vodafone125 with infinity box here the logs COM19 [VCP1] selected module v1.57 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20081127-135523.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20081127-135524.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081127-135531.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20081127-135537.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 37 sec Remove/Install battery now ! thax infinity team |
@sonumobilewala Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
