Old 11-27-2008, 09:27   #1 (permalink)
sonumobilewala's Avatar
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
susessfully unlock vodafone125 counter block
hi frand today i sucsessfully unlock vodafone125 with infinity box
here the logs
COM19 [VCP1] selected
module v1.57
Device: ZTE-125
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20081127-135523.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20081127-135524.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081127-135531.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20081127-135537.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 37 sec
Remove/Install battery now !
thax infinity team
The Following User Says Thank You to sonumobilewala For This Useful Post:
Old 11-27-2008, 19:59   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@sonumobilewala
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems (so we will be able to fix it) and successfully done work.
9500 Blackberry Unlock Counter Blocked [COUNTER BLOCKED | IMPOSSIBLE] cilian FuriousGold 8 11-18-2010 11:51
how to unlock bb counter blocked???? arnod06 BlackBerry (RIM) 4 11-14-2009 10:47
Help !! ....5310 Code Counter Blocked !! how to reset 3/3 counter N/East Unlocker Cyclonebox 2 10-07-2009 09:54
vodafone 226 to unlock-counter blocked-how unlock zonetrichur Infinity-Box 2 08-03-2008 19:48
ZTE A35 counter blocked - unlocked successfully snsoftkiller FuriousGold 11 04-12-2008 14:05
Page generated in 0.23359 seconds with 8 queries
