04-15-2015, 06:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Swipe connect 4e V2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B Configure emi settings Error : DA init Failed! Error code : 0x5 can i alive this phone? pls help me |
04-15-2015, 10:35 | #5 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | just try boot cable( for spd6820 - or mt6575 ) and some windrows 7 pc x64 ( if you use) have issue of driver signature issue ) change port may also help |
04-15-2015, 10:38 | #6 (permalink) | |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
04-15-2015, 13:38 | #9 (permalink) |
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | this firmware 2014.9.19_20SWIPE_KONNECT4E_S138AEA_DX01_Z135_V0.7 .777 |
04-15-2015, 14:08 | #11 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
try to find other frimware and only write preloader file with cm2 By Init Preloader option on the extra tab@ Hi bro This Tool Does Not Work In 6571 ChipSet- | |
04-15-2015, 14:25 | #12 (permalink) |
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | [QUOTE=pradeep_kus;10988185]try to find other frimware and only write preloader file with cm2 By Init Preloader option on the extra tab@ not done sir Chinese Miracle II [MTK module] v 1.17 User selected Preloader file : preloader_s5202ap.bin Operation : Init Preloader [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
