08-16-2017, 08:39 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Dhaka Bangladesh
Member: 1769406 Status: Offline Thanks Meter: 15 | how to remove frp lava iris 80 ver-7.0 ... n when i try with press both volume key TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!.... pls any one help me |
08-19-2017, 13:31 | #3 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Bangladesh
Member: 1076772 Status: Offline Sonork: 100.1601881 Thanks Meter: 2,847 | LAVA IRIS 80 Frp Remove File LAVA IRIS 80 Frp Remove File Use this file ver LAVA_iris80_INT_S109 |
The Following 2 Users Say Thank You to JONONItelecom™ For This Useful Post: |
12-16-2017, 08:58 | #9 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2787598 Status: Offline Thanks Meter: 0 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447383421A532B5145130 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! ITS NOT WORKING |
03-15-2018, 07:42 | #11 (permalink) |
Insane Poster Join Date: Aug 2008
Member: 839068 Status: Offline Thanks Meter: 8 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
