Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jul 2004 Location: Russia. Khakassia Age: 37
Member: 72306 Status: Offline Thanks: 5
| sx210 after format phone come with reload. After comlete format see this log COM23 [Serial2] selected Device: Fly SX210 Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... warning: incorrect bootloader header: 426F6F746C6F61646572610056707075 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Finished, time used: 30 sec Remove/Install battery now ! Can i revive this phone? WBR, Igor Bublik |
| | #3 (permalink) |
| After flash 2 any flash file i make rebild imei....see log COM23 [Serial2] selected Action: imei imei write method: mode-2 new imei: 355252010538047 Model: Fly SX210 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 110 sec Remove/Install battery now ! |
| | #6 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| 1. Flash phone with firmware from support area 2. make "complete" format what is the results ? There is no any reason to repair imei if phone can't start ! |
| | #7 (permalink) |
| COM23 [Serial2] selected Device: Fly SX210 Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page+spare converting data... done 0x01717600 bytes identification#1 protocol ver: 04 ver. sw1: SLT100_MERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_36 _MP_V25.BIN ver. sw2: MAUI.06A.W06.36.MP.V25, 00000000 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... warning: incorrect bootloader header: 426F6F746C6F61646572610056707075 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... write core area 1 of 2... write core area 2 of 2... Write Done Finished, time used: 400 sec Remove/Install battery now ! COM23 [Serial2] selected Device: Fly SX210 Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... warning: incorrect bootloader header: 426F6F746C6F61646572610056707075 nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned error: can't detect ffs address Identification Fail Finished, time used: 26 sec Remove/Install battery now ! not work...any solution? Igor Bublik |
| | #8 (permalink) |
| Hello, Try to write another firmware. If still the same resuts after another flash file my advce is: reball flash chip |
| | #9 (permalink) |
| flashing not work. maybe fullflash with Flashtool? I need loader for flash.... WBR, Igor Bublik Offtopic I have on hand Voxtell 2iD. have original flash v6 and flasher. Meybe add this to infinity? |
| | #10 (permalink) |
| Hello, I don't think that flashing with FlashTool can helps in this situation. 2iD: please, send files to InfinityBoxSupport@gmail.com and we will check it |
| | #11 (permalink) |
| uploaded to e-mail....please close the topic (i am not found....why?) WBR, Igor Bublik Last edited by Igorbublik; 02-27-2008 at 02:04. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| TV N95 Only English Language after format and After Falash | Tracer Gsm | Chinese Models & Cloned Phones | 1 | 02-04-2009 20:36 |
| Help after formatting M65 | Rossifan | S-Gold Based Phones | 1 | 12-13-2004 15:08 |
| 6600 4Xblinks after format user area | dey_it | Griffin | 4 | 06-05-2004 21:21 |
| Problem after format laptop | ps2solutionsuk | UFS2 + UFS3-Tornadoflasher | 5 | 04-13-2004 01:12 |
| After format and instal 2 problems!!! | sergioems | Off Topic Zone | 7 | 02-25-2004 14:11 |
