Symphony Helio S10 Patter Lock Not Done & Hang Logo Today, My shop Come Symphony Helio S10, Problem is pattern Lock, Hang Logo Now After Full Reset by Cm2 1.58 Log is Here: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207A802AA60341D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x148975AD17F329E75D46BAA34B19D541 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Helio ProdName : S10 ProdModel : S10 Device : S10 AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : SWW1609SY_0303_T7083 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207A802AA60341D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x148975AD17F329E75D46BAA34B19D541 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D4207A802AA60341D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x148975AD17F329E75D46BAA34B19D541 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
HELLO @mcclinic RESET AGAIN FROM RECOVER MODE AND WAIT FOR 10 TO 15 MIN IT WILL ON GOOD LUCK |
"encrypted" user area, im already solved by Factory Firmware with "spflashtool" i want to say why encrypted cpu Not update our Favourite infinity Team. |
1. There is exists ENCRYPTED USER AREA, but not "ENCRYPRTED CPU" 2. WIPE mode. |
