06-29-2019, 15:08 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bd,Dhaka,GSM CLUB Age: 38
Member: 859030 Status: Offline Sonork: 100.1619336 Thanks Meter: 435 | Card found : D3C48C8C , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:27 |
The Following 2 Users Say Thank You to ..:::GSM CLUB™:::.. For This Useful Post: |
08-26-2019, 08:11 | #4 (permalink) |
Junior Member Join Date: Nov 2015 Location: Bangladesh
Member: 2485368 Status: Offline Thanks Meter: 11 | Symphony i95 Spd Cpu Frp Lock Remove 100% Cm2. Thank you For InfinityBox CM2 Team.. Operation : Format FS / Reset Settings [ v2.00r2 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
The Following User Says Thank You to gsmripon For This Useful Post: |
01-20-2020, 18:58 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I am afraid you are trying to advertize your web page here but your links are fake. If you really have good working file pls upload it somewhere withiut password. f.e. you can use mega or other good file sharing service. also you can use iosFileUploader. |
01-20-2020, 19:03 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | It looks like you are trying to advertize your youtube channel in Infinity-Box support forum. If your channel has videos about Infinity software please use THIS but if your videos has no relation with Infinity software please use another forum section. thank you ! |
