08-01-2017, 15:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: CHOLOMAN
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | SYMPHONY P9 FRP. How to solve? Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
08-01-2017, 16:17 | #3 (permalink) |
Member: 1440339 Status: Offline Sonork: 100.1616914;CHOLOMAN Thanks Meter: 116 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423158BD890742499A6996 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to .::JYOTIRMAY::. For This Useful Post: |
09-10-2017, 12:41 | #6 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | it's up to android version 7.0 so there is no problem solving yet .......... wait some day's please update cm2 mtk platform.................. |
The Following User Says Thank You to pintu_das For This Useful Post: |
09-10-2017, 18:52 | #8 (permalink) |
Freak Poster Join Date: Nov 2015 Location: dnj.bd
Member: 2484144 Status: Offline Sonork: QQ_3272429273 Thanks Meter: 318 | Securityboot_boot_not_accepted symphony i10+ mt6580 symphony p9 mt6735 symphony v120 mt6580 |
The Following 3 Users Say Thank You to rmstk For This Useful Post: |
10-02-2017, 07:42 | #10 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2689377 Status: Offline Thanks Meter: 1 | Securityboot_boot_not_accepted symphony i10+ mt6580 symphony p9 mt6735 symphony v120 mt6580 Huawei Y3II LUA-U22 Mtk6580 TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! |
The Following User Says Thank You to himelcomputer For This Useful Post: |
11-05-2017, 16:35 | #11 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | i done with this mehtoud.....https://goo.gl/87WZHD |
The Following User Says Thank You to the boss atik For This Useful Post: |
