07-09-2017, 06:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Symphony roar v20 MTK not support please team see it Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to shanawas_1 For This Useful Post: |
08-24-2017, 08:18 | #5 (permalink) |
Junior Member Join Date: Nov 2015 Location: Bangladesh
Member: 2485368 Status: Offline Thanks Meter: 11 | Symphony Roar v20 Frp Lock Remove Solution Plz. Cm2 Not Done. Help Me Any Boss. Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following User Says Thank You to gsmripon For This Useful Post: |
12-04-2017, 11:11 | #9 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2784241 Status: Offline Sonork: 100.1679467 Thanks Meter: 0 | Card found : S/N : 7EC4302C , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
