Symphony V49 Flashing Problem Symphony V49 V9 HW2 It Was Virus Effected I Was Backup After Flash Now Phone Dead Due To Reason Downgrade and Now Phone Is Not Accepted Via CM2 Or SPD tool I m Trying Also With Backup And Current Version But Allways Cm2 Software Stuk And No Respond... SPD tool Is Too Same I need help team plz https://s15.postimg.org/w0bxqp4cr/cm2_2.jpg https://s15.postimg.org/af6v337m3/cm2_1.jpg |
Up.................................... coustomer is so excited |
check the file again.. its .pac.sc.. also try with and without ALTERNATIVE LDR MODE... post result please |
i allready trying but ... no result |
i have all versions firmware and and all firmware same ... not flashed... |
There is no any DG prevent check, so go to HW part and check it. |
The device is not accepting loader also neither is factory tool not in CM2, there is nothing issue in the SW side, Need to check at HW side |
You must understand, instead SOFTWARE PROBLEMS - exists HARDWARE PROBLEMS as well. And it not depend on you. If you can open phone and resolder it - then do it. Also not forget about battery. It must be charged. Dead device NOT charge it. |
try with mirracle box it's work 98% |
