Old 09-29-2015, 19:18   #1 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
symphony w85 pass protetct
how can remove pass without userdata loss i try cm2 1.32 v reset pass thik userdata ok but same lock
Old 09-30-2015, 06:18   #2 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
help any one ......................
Old 09-30-2015, 06:28   #3 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 423
post log if u need help
Old 09-30-2015, 07:22   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,658
There is 2 types : User Locks - PIN/PASS/Gesture and e.t.c. and PrivacyLock - every from those 2 have own button. Not hard to select correct one, instead of waste much time.
Old 09-30-2015, 07:30   #5 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 596
seem pob face me huwai y511-u30 format and flash but steel lock .... use sptool do format with sp tool seem and formet and flash .thik and do down-lode in sp tool seem ..... use many china porfconel .. tool etch miercal and volcano gpg dragon .. noting happiness
Old 09-30-2015, 08:02   #6 (permalink)
JayDi's Avatar
Member: 462970
What you smoke? There is INFINITY section. And INFINITY can easy remove "PRIVACY" lock EVEN WITHOUT ANY BYTE OF USERDATA LOST.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-30-2015, 09:17   #7 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
w85 user lock log 1. Power Off Phone , Remove battery , Insert back
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048603A32AA021A7
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048603A32AA021A7
[eMMC] : FLASH_EXT : 00200000/00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
LSSA Ok!
LSSW Ok!
LSSS Ok!
Security Settings : Clear Ok!
[Info] : Android 5.x / MT67xx : If phone stuck on "Logo"
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
just full info
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.32 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:10
Old 09-30-2015, 09:32   #8 (permalink)
JayDi's Avatar
Member: 462970
@SAJONDUTTA, enough smoke too. Check thread again from start and you will find all answers in one post.
Don't waste our and your time.
Old 09-30-2015, 09:41   #9 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
JayDi sir do some thing i need user data recover
Old 09-30-2015, 09:43   #10 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
explane me now what can i do set same lock
Old 09-30-2015, 09:52   #11 (permalink)
JayDi's Avatar
Member: 462970
Send phone to someone, who can press need button and tick need option, please. Save your time.
Old 09-30-2015, 10:00   #12 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
this not solution i respect infinity teem why u naver help
Old 09-30-2015, 10:03   #13 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
so u naver help at last i do hard reset all my user data delet thanks jaide
Old 09-30-2015, 10:14   #14 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 639
Hello
which type of lock u have is it privacy r Pin Cm2 both supported with out data loss u can save ur data with out a byte also
Old 09-30-2015, 10:23   #15 (permalink)
JayDi's Avatar
Member: 462970
You must learn, not just waste time. If you can't read your thread, and simply tell exact problem, what done, what result and what tried - then better not ask anything at all.
Page generated in 0.43979 seconds with 7 queries
