T 128 huawei a t 128 came in with blinking keypad and blue display(glowing continously) i flashed the main nad eeprom with the file s available in the support,after that it started restarting with airtel logo continously,may i request for the help to solve the problem. ==== log: [12/25/2008 2:01:27 PM] ==== COM5 [VCP0] selected Device: Huawei-T128 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-sta_20081225-140146.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-sec_20081225-140150.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128_eeprom-complete_20081225-140205.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 297 sec also i can see this error in log is this a error or normal wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106/ Thanks |
Hello, Make "sp-unlock" operation now. |
hello sir as per ur above guidence i have done the unlock and the set is ok now thans so much and good wishes for the happy new year. |
