02-22-2008, 21:27 | #1 (permalink) |
Banned Join Date: Feb 2007 Location: India
Member: 445282 Status: Offline Thanks Meter: 28 | T 689 second sim error Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 354101000245157 Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2200:18E59F00000000 flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... ......... detect device identification#1 finished identification#1 protocol ver: 02 ver. sw1: E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN ver. sw2: E550AGENT_S1.01.5, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: 01227E221A2200:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00300000 Detected eeprom/ffs address is non-standard: 00300000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00300000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00300000-003FFFFF reading [eeprom[E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN]_20080222-144114.B0E.bin flash: 01227E221A2200:18E59F00000000 Identification Done Manipulation... 2 step(s) required to finalize Manipulation Done Finalization... Finalization Done Write... flash: 01227E221A2200:18E59F00000000 Write: eeprom Write Done Finished, time used: 167 sec Remove/Install battery now ! After write imei still same problem. this is my log file pls help me infinity.thanks |
---trend t500 dual sim second sim is not working any solution--- | makkah mobile | Infinity-Box | 1 | 09-12-2008 09:26 |
T689 second sim is going off | zoki | Infinity-Box | 40 | 05-01-2008 16:22 |
Cect T 689 dual sim | alunecosu_hd | Infinity-Box | 4 | 04-01-2008 14:23 |
CECT T869 Second sim never Work | thetissot | Chinese Models & Cloned Phones | 1 | 10-27-2007 19:56 |
Second SIM-card at once management? | IvanKrasnyj | Hardware Equipments for GSM | 0 | 05-09-2002 04:21 |
