06-30-2011, 12:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Mauritius Port Louis
Member: 762522 Status: Offline Thanks Meter: 156 | t mobile zest blinking only after unlock Any idea plzzz?? COM28 [VCP0] selected module v3.73 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7F37:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.73, database date: 19.01.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B05.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B05.BIN project-id: TMO_UK_P109A17V1.0.1B05, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00600000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98009600000000:2AEA0000000000 Backup required data Done ====> Patch required data ... ................... lock area found ................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................. required data found flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: area 1 (pass 1) .............. area 1 patch applied Ok Special operation Done ====> Write ... flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: lock-area-1 flash: 98009600000000:2AEA0000000000 flash: 98009600000000:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 1 min 1 sec Remove/Install battery now ! |
06-30-2011, 14:37 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @k-mobile I suggest you download and install latest MModule software from support area. Also, during unlock, do not change unlock method (until you are sure that you must do it). |
07-01-2011, 10:22 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Use this file from support area ! ZTE-R221_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B05_2010-10-14_En_T-Mobile-Zest.B0M.bin |
07-01-2011, 14:08 | #8 (permalink) |
Member: 762522 Status: Offline Thanks Meter: 156 | while flashing its says write error!! Any idea????? here is log COM1 [Serial0] selected module v3.73 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware SFR-115_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B03_2011-01-20_En_Fr_Es.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7F37:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.73, database date: 19.01.2011): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-R9SM-P109A17V1_0_4B06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-R9SM-P109A17V1_0_4B06.BIN project-id: VE-VN-R9SM-P109A17V1.0.4B06, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98009600000000:2AEA0000000000 Write: Firmware jump to next chip: 01 flash: 98009600000000:2AEA0000000000 Write: Firmware error: write operation failed Write Fail Finished, time used: 13 min 53 sec Remove/Install battery now ! |
07-01-2011, 18:26 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Flash done with ZTE-R221_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B05_2010-10-14_En_T-Mobile-Zest.B0M.bin THANKS SUPPORT COM1 [Serial0] selected module v3.63 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware ZTE-R221_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B05_2010-10-14_En_T-Mobile-Zest.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7F37:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.3.63, database date: 20.10.2010): ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B03.BIN project-id: EFS-SFR-R9SM-P109A17V1.0.4B03, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B03__ffs... file saved: C:\Program Files\InfinityBox\MModule\T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.EFS-SFR-R9SM-P109A17V1_0_4B03__ffs_20110701-211145.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98009600000000:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 16 min 24 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
