Old 05-10-2011, 16:05   #1 (permalink)
Member: 482296
Thanks Meter: 43
T MOBILE zest dead after unlock
i have tmobile zest after unlock not power on only blinking i flash with r221 and also metfone firmware but same result i am using mm module 3.87
Old 05-10-2011, 16:09   #2 (permalink)
Member: 1043909
Thanks Meter: 51,293
it can not be true that our software damage this phone !
if you killed phone by some way - use files from t-mobile-zest folder !!!
Old 05-10-2011, 16:10   #3 (permalink)
Member: 482296
Thanks Meter: 43
Device: T-Mobile-Zest
==== [5/10/2011 6:10:39 PM] ====
COM9 [VCP0] selected
module v3.87
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:4DA3:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98009600000000:2AEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb
otp offset: 007F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.3.87, database date: 01.05.2011):
ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B07.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 07
sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B07.BIN
project-id: TMO_UK_P109A17V1.0.1B07, 00000000
code offset: 00000000
ffs offset/size [02]: 00600000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00600000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 48 sec
Remove/Install battery now !
Old 05-10-2011, 16:10   #4 (permalink)
Member: 482296
Thanks Meter: 43
i also flash zest foder flash files but same
Old 05-10-2011, 16:19   #5 (permalink)
Member: 1043909
Let's hope next time you will be more careful and you never change default settings in software !
if you change something - you must think twice and at lest you must make full flash backup.
do you have ORIGINAL full flash backup ?
Old 05-10-2011, 16:19   #6 (permalink)
Member: 482296
Thanks Meter: 43
yellow boss need your urgent reply thanks in advance
Old 05-10-2011, 16:23   #7 (permalink)
Member: 482296
Thanks Meter: 43
do you have ORIGINAL full flash backup ? my answer is no
i don.t have flash backup so what to do now?
Old 05-10-2011, 16:30   #8 (permalink)
Member: 1043909
you must charge battery with external power supply and flash phone once again with R221 + T-Mobile-Zest 8Mb flash files.
if it will be no luck you can make full flash backup now and send it to [email protected] but we can not promise that we can repair your file.
Old 08-19-2011, 13:46   #9 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 52
I have the same problem . I try unlock zte R221 and after said Done the phone is dead! i have fullflash backup and i write in the phone but not work !
Old 08-19-2011, 15:41   #10 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 52
Please i need help !
Old 08-19-2011, 19:50   #11 (permalink)
Member: 1043909
I think phone can not be damaged.
what you have tried to do with phone exactly ?
Old 08-20-2011, 18:57   #12 (permalink)
sdr
sdr's Avatar
Member: 25136
Sonork: 1591036
Thanks Meter: 52
Talking
1. I make full flash backup .
2. I have selected read codes and program is read codes but i didnt how enter in the phone .
3. I have selected direct unlock and demage my phone .
4. I write my fullflash backup the phone dosent start .
5 I write a flash from the forum but dosent power on .
6 I write another flash for the forum and the phone not power on.
7 I write again my fullbackup and phone is alive
8 I have selected direct unlock esey method and the phone is unlocked.
PROBLEM is SOLVED . Thank's !
Old 08-30-2011, 14:10   #13 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
just unlocked one from Tmobile UK without any problems by just reading codes. Less than 10 seconds.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 15:21
Page generated in 0.44139 seconds with 8 queries
