10-19-2010, 19:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: K'dua , 3rd Fl Main K'si St GH
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | T-mobile Zest Phone Files for Support to Consider. 1. Cable GW300 2. Mmodule 3.62 3. i selected Alcatel 203 and ZTE-N281 these are the files Alcatel-203X,203A,203E_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00. TMO_UK_P109A17V1_0_1B04__ffs_20101019-180103.B0E.bin - 4shared.com - online file sharing and storage - download Alcatel-203X,203A,203E_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00. TMO_UK_P109A17V1_0_1B04__fullflash_part_1_of_1_201 01019-180629.B0M.bin - 4shared.com - online file sharing and storage - download Alcatel-203X,203A,203E_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00. TMO_UK_P109A17V1_0_1B04__firmware_part_1_of_1_2010 1019-175953.B0M.bin - 4shared.com - online file sharing and storage - download ZTE-N281_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__firmware_20101019-174603.B0M.bin - 4shared.com - online file sharing and storage - download COM3 [VCP2] selected module v3.62 Device: ZTE-N281 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6223:8A05:8A00 status: FF bbchip bl ver: FE NOR flash id[009C]: 00EC:257E25062501 [SAMSUNG] K5L6331CAA chip size: 8Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: 0BE7:S_DA_NFI_NOT_SUPPORT internal RAM size: 0000A000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: TMO_UK_P109A17V1.0.1B04 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B04.BIN project-id: TMO_UK_P109A17V1.0.1B04, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 6Mb number of areas/bytes to read: 1:00600000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files\InfinityBox\MModule\ZTE-N281_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__firmware_20101019-174603.B0M.bin Disconnect... done Finished, time used: 7 min 7 sec Remove/Install battery now ! Please i hope the team will consider the above for unlock. |
The Following 3 Users Say Thank You to mediaextensions For This Useful Post: |
10-20-2010, 18:28 | #2 (permalink) |
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | I unlocked the Tmobile Zest by selecting ZTE-R221. COM3 [VCP0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: boot initialization step #3 failed: 00 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6E91:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403078409 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following 7 Users Say Thank You to mediaextensions For This Useful Post: |
10-20-2010, 19:12 | #4 (permalink) |
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | Ok , then it implies that the ZTE labelled Tmobile Zest is the same as ZTE-R221. check here too http://forum.gsmhosting.com/vbb/f425...9/#post6469563 YellowBoss , thanks , Please i suggest if you can include Tmobile Zest name under ZTE. |
10-20-2010, 19:33 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please, post here exact text from phone back label. I need to check it due to as I can see there are several phones with quite different hardware but with the same mark like "ZTE-R221". |
10-20-2010, 19:35 | #6 (permalink) |
Member: 1123079 Status: Offline Sonork: 100.1586814 Thanks Meter: 439 | The exact text at back of phone is TMOBILE ZEST as model, i google the image and it was exactly what i was holding. Unfortunately i have given phone to customer already. |
The Following User Says Thank You to mediaextensions For This Useful Post: |
10-30-2010, 06:03 | #7 (permalink) |
Freak Poster Join Date: Dec 2007 Location: somewhere in KENYA
Member: 648607 Status: Offline Sonork: 100.1638674 Thanks Meter: 23 | SELECT ZTE R-221 .1000000000% working,thanks to infinity team |
The Following User Says Thank You to joseck For This Useful Post: |
10-31-2010, 12:47 | #8 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kotli
Member: 643478 Status: Offline Sonork: 100.161898 Thanks Meter: 159 | COM12 [VCP1] selected module v3.63 Device: ZTE-R220 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6CA6:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B04.BIN project-id: TMO_UK_P109A17V1.0.1B04, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00600000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25062501:2AEA0000000000 Backup required data Done ====> Patch required data ... ................... lock area found ................... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch detecting parameters to apply patch area 2... .................................................. .............. error: area 2 can not apply patch Special operation Done ====> Write ... flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: lock-area-1 flash: EC257E25062501:2AEA0000000000 flash: EC257E25062501:2AEA0000000000 Write: lock-area-4 Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 7 sec Remove/Install battery now ! not done any other solution? |
The Following 2 Users Say Thank You to moon955 For This Useful Post: |
11-04-2010, 00:31 | #9 (permalink) | |
Select correct model (T-Mobile-Zest) and try again. | |
11-05-2010, 11:31 | #10 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | COM12 selected module v3.63 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5C7F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403181705 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now !tested ok thx |
The Following 2 Users Say Thank You to damabib For This Useful Post: |
11-08-2010, 11:22 | #11 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 46
Member: 112392 Status: Offline Thanks Meter: 11 | Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:77DA:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403171894 connection Ok 192 byte(s) read reading data... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 33 sec Remove/Install battery now ! Thanks working |
The Following User Says Thank You to zeeshankhadim For This Useful Post: |
12-01-2010, 13:37 | #12 (permalink) | |
No Life Poster Join Date: May 2003 Location: LONDON Age: 54
Member: 28670 Status: Offline Thanks Meter: 38 | tmobile zest dead. Quote:
for me not working the phone dead now,iflash the phone but still dead. tmobile zest please any info to revive it. thanku. | |
12-01-2010, 14:09 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @billyuk009 Please, tell me, what was the problem with phone and what you have tried to do exactly. - What was with phone when you got it ? - Did you tried to flash it ? - If yes, what flash files you have used ? - Did you tried to unlock phone ? - What was the results ? - What was original phone firmware version ? - Do you have original full flash backup ? Also, please, post here operation logs for each operation. Thank you very much for your explanation ! |
12-01-2010, 14:45 | #14 (permalink) | |
Member: 28670 Status: Offline Thanks Meter: 38 | her is the log thanku. Quote:
the phone is brand new itrayed to unlock it, after the phone dead itray to flash it just bilink her is logCOM24 [VCP0] selected module v3.70 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04_2010-07-12_En.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T-Mobile-Zest_ffs_01.B0E.bin ====> Boot ... Press and HOLD Power button now ! error: boot initialization step #2 failed: 00 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:72CA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B04.BIN project-id: TMO_UK_P109A17V1.0.1B04, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00600000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98009600000000:2AEA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98009600000000:2AEA0000000000 Write: Eeprom/ffs usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 98009600000000:2AEA0000000000 Finalization Done Finished, time used: 14 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
