02-17-2009, 08:07 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | T128 successfully unlock module v1.60 Device: Huawei-T128 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090217-000137.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090217-000138.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090217-000144.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090217-000204.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to nadirghazi For This Useful Post: |
02-18-2009, 19:53 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
03-27-2009, 15:48 | #3 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | COM8 [VCP0] selected module v1.64 Device: Huawei-T128-HW-A Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 007 T128MZ 11 21 31 O Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-static_20090327-201347.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-security_20090327-201349.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-complete_20090327-201404.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Write Done Finished, time used: 52 sec Remove/Install battery now ! unlocked successfully thanks...regards! |
The Following User Says Thank You to syed.n For This Useful Post: |
E75 Success Unlock!!! | jr astigin | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-29-2010 11:19 |
Post Here Successfully unlocked using SE A1 Fast Java unlocker | bhart | Cruiser Suite | 90 | 01-27-2009 22:07 |
Huawei T128 Successfully Unlock With Infinity | .::AZEEM::. | Infinity-Box | 11 | 01-13-2009 19:01 |
Huawei T128 Successfully Unlock With Infinity , Again A Great Work Team. | amit_varietymob | Infinity-Box | 8 | 08-30-2008 07:08 |
