Old 11-24-2016, 08:03   #1 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 360
T200 Qmobile after erase showing block red sign at signals help
flashing log with erase:
Infinity SC Firmware Detected
FW Size : 892 MiB
Load Ok!
Start  at : [11/23/2016 / 12:07:47 PM]
Operation : Flash [ v1.19 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 29 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : User decide to make whole erase
[FL] : FLASH_FULL_FORMAT executing , wait ...
[FL] : FLASH_FULL_FORMAT Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Update NVM image : nvitem.bin
Update NVM Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_modem_CP2_WCN_14E_W15.16_Release.bin
Write Data ...
Write Data Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : hwinfo.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:03:24
Reconnect Power/Cable!
Finish at : [11/23/2016 / 12:11:44 PM]
now imei ok.
showing red block sign at signals.
network option hidden in setting.
when make a call, showing a msg " 1st disable flight mode then try again " (flight mode already dissabled)
any solution????
Page generated in 0.11566 seconds with 8 queries
