09-16-2009, 19:58 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri lanka Age: 44
Member: 700923 Status: Offline Thanks Meter: 13 | T33i aftre format not on module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:A403:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #04 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #05 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #06 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #07 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is damaged, recalculation required rom info detection finished device-id: 6A83C869 rom info protocol ver: 05 ver. sw 1: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.T33+_083 2_SAMSUNG64X32_V008.BIN ver. sw 2: T33+_0832_SAMSUNG64x32_V008, 885CB35A ffs offset/size: 00770000/00090000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00770000 flash: EC257E25062501:2BEA0000000000 checking area [00000000]: 00000000-007FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00770000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00090000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00770000-007FFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GSM_MT6225_S00.T33+_083 2_SAMSUNG64X32_V008__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_08A_GEM INI_PCB01_GSM_MT6225_S00.T33+_0832_SAMSUNG64X32_V0 08__ffs_20090916-234142.B0E.bin flash: EC257E25062501:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: EC257E25062501:2BEA0000000000 Finalization Done Finished, time used: 189 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
help me N99 tv phone after format not on | w850 | Infinity-Box | 2 | 08-05-2009 22:12 |
D600 pressed format nand on ufs3 wat now? | JOHN2003. | UFS2 + UFS3-Tornadoflasher | 1 | 02-26-2009 22:31 |
after formating phone is not on | ameho0102 | Chinese Models & Cloned Phones | 5 | 09-26-2008 01:21 |
formate ok but set not on | ameho0102 | Chinese Models & Cloned Phones | 8 | 09-11-2008 14:20 |
help formatting mmc on 9210i | hacksat2004 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-02-2004 23:19 |
