Old 04-11-2008, 16:19   #1 (permalink)
Member: 744651
Thanks Meter: 20
Urgent Need Cable for MPEG4 P888i
Hey Guys,
I just bought an Infinity Box and set of cables that were recommended for Chinese Phones. I bought these things specifically to repair a number of Chinese MPEG4 P888i handsets that I have that keeps switching on and off when the sim cards are placed in the phone.
Sadly, I did not get a cable to fit this phone in the 60+ cables that i have.
Can someone help me locate this cable, or is it possible, that I can take one of the data cables for the phone and add an RJ45 jack to it and work it that way?
Old 04-11-2008, 16:23   #2 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
what's conector type??
try locate GND on it
check what's CPU type inside phone (maybe it's Spreadtrum CPU)
br
Old 04-11-2008, 20:13   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, start from opening phone and checking which MCU it is based.
you had to buy our pinout finder, this would be bettter than 60 cables.
but as long as you didnt- we will advice you how to make own cable.
just need to find pinout.
but i repeat- start from checking MCU type
Old 04-12-2008, 13:56   #4 (permalink)
Member: 744651
Thanks Meter: 20
Hey Bourri GSM, thanks for your response, i'm a complete rookie to these things, can you tell me how to find this.
Old 04-12-2008, 13:59   #5 (permalink)
Member: 744651
Thanks Meter: 20
Hi Infinity Help
hello!
Hi,
Thanks for your quick response, as mentioned, i'm a complete rookie to this, but not technically challenged, can you give me a little guidance on how to go about cheking the MCU type? and pinout
Thanks
Old 04-12-2008, 16:10   #6 (permalink)
Member: 148515
hello!
just open phone, remove metal shield and check what is written on MCU.
if this MCU is supported by infinity soft- i will advice how to find pinout
Old 04-13-2008, 00:11   #7 (permalink)
Member: 744651
Thanks Meter: 20
hello!
Hi,
Don't mean to sound daft, but what's the MCU?...is it labelled?...do I have to remove the housing?
Old 04-13-2008, 13:34   #8 (permalink)
Member: 148515
hello!
MCU is main control unit, processor in other words.
yes, to see it's type you need completly disassemble phone
Old 04-17-2008, 21:52   #9 (permalink)
Member: 744651
Thanks Meter: 20
Still Cannot find MCU
Hi,
I completely disassembled the handset, but still cannot find MCU type...please help, I have pictures, can you tell me where i can email them?
Old 04-17-2008, 22:18   #10 (permalink)
Member: 744651
Thanks Meter: 20
Can I email you pictures of the phones?...please email me.. [email protected]
Old 04-18-2008, 00:09   #11 (permalink)
Member: 148515
hello!
drop email with pictures to [email protected]
Old 04-22-2008, 00:33   #12 (permalink)
Member: 744651
Thanks Meter: 20
Pictures sent to your email
Old 04-22-2008, 01:09   #13 (permalink)
Member: 148515
hello!
email recieve, this is double MCU phone.
poinout you can find by yourself if you measure voltage on all phone pins.
Data lines will show 2,7-2,9 volts
Old 04-22-2008, 12:09   #14 (permalink)
Member: 744651
Thanks Meter: 20
Hi,
Still brings me back to not having a cable for it, how can I make one?
Old 04-22-2008, 18:52   #15 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
software version: 1.07
cable type: 1x12 (L12C)
platform: MT62xx (autodetect)
searching adapter at COM17...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6226
result: Rx:10 Tx:6
time required: 56 sec
reverse
platform: MT6205, MT6217-MT6228
pins: 12, reversed !
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
CPU: MT6226
result: Rx:3 Tx:7
time required: 16 sec
!!! Urgent !!! Need Schematics For Unlocking Cable 4 Ericcson A2628 colonic Old Ericsson Phones & Sony Phones 2 01-15-2004 12:03
urgently need flash for 8850 - for flasher 1 (through log) aod@gsm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-18-2002 05:15
urgently need C4_10_87 for V2288 GSM Deals Motorola Old Legacy (EMMI) 3 01-22-2002 22:02
Urgent need dump for sagem 922 sashpeto Infineon C16X M51 & ARM7 M52 BASED 0 08-05-2000 23:02
Please, I urgently needed soft for N3210 v 4.65 MP Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-08-1999 10:29
Page generated in 0.24814 seconds with 10 queries
