Old 02-13-2009, 14:50   #1 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
t590 dead during formate
i have t590 sony ericson it was restarting i try to formate it but in the end gavis erorr here is the log file
COM8 [VCP1] selected
module v2.73
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6217:8A00]...
CPU: MT6217
high speed boot On
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 29EA00F018E59F:29EA0000000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00700000
checking area [00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 00700000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090213-064708.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
error: no any expected answer
error: flash erase error: 00700000
Finalization Fail
Finished, time used: 185 sec
Remove/Install battery now !
Old 02-13-2009, 19:49   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
try to resolder flash chip or at least heat it
N95 V3 Type Jack Dead-did Format Ffs-still In Dead zonetrichur Multi-Box 4 05-15-2008 13:24
an error during format ffs --help zone2 Infinity-Box 3 03-07-2008 08:34
c72 during formating mobi4u S-Gold Based Phones 6 08-23-2006 21:28
SL45 Dead During hearing MP3 Songs. DrMobile x1x to x45/x50 14 10-31-2002 12:56
Help!!! Mars is dead during flashing... Roman Mitsubishi 1 11-27-2001 20:20
Page generated in 0.23024 seconds with 9 queries
