04-23-2019, 12:00 | #1 (permalink) |
Insane Poster Join Date: May 2017 Location: iran
Member: 2713606 Status: Offline Thanks Meter: 239 | Ta-1017 Flashing Problem please help me i want to flash nokia Ta-1017 with another language pack firmware but in flashing show this error and phone dead! Flash_Write ERROR : DA_CBR_NOT_FOUND i take backup from phone's firmware before flashing' but same problem and same error i tested alot of backed up firmware's from normal phones and with same product code Please Give solution |
04-23-2019, 16:23 | #3 (permalink) |
Member: 2713606 Status: Offline Thanks Meter: 239 | Operation : Write FirmWare [ v1.15 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM414) MODE : NOKIA USB SERIAL PORT : 414 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 51055F5414F0532CA1D36F54F579B8E4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 10.00.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IJ_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IJ_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IJ_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IJ_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
04-23-2019, 17:04 | #4 (permalink) |
Member: 2713606 Status: Offline Thanks Meter: 239 | Open VPLfile : TA1017_059Z1Z6_11.02.11.vpl Description : TA-1017 NDT MEA IJ BLACK FARSI IR DeviceType : TA-1017 ProductCode : 059Z1Z6 SoftwareVer : 11.02.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.15 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM414) MODE : NOKIA USB SERIAL PORT : 414 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 51055F5414F0532CA1D36F54F579B8E4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IJ_MEA_IR_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IJ_MEA_IR_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! another file same problem |
05-05-2019, 00:55 | #9 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
