03-30-2019, 16:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | ta-1056 dead after flash Card found : S/N : 7DB1869C , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6752 , Project : frt , Storage : EMMC Files found : 19 , Set to Flash : 18 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 129 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447385637A53273E8A0EF Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A53756EFA03573 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x05E7B28E23DD2C979E9BC165152D5B8D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6752 , Project : frt , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4354 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000001CF300000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001E Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : ODMDTBO Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYSTEMINFO Image Flash Ok Flash now : SUTINFO Image Flash Ok Flash now : CDA Image Flash Ok Flash now : DEVICEINFO Image Flash Ok Flash now : ELABEL Image Flash Ok Flash now : VENDOR Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:35 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : ODMDTBO Verify Passed : BOX Verify Passed : SYSTEMINFO Verify Passed : SUTINFO Verify Passed : CDA Verify Passed : DEVICEINFO Verify Passed : ELABEL Verify Passed : VENDOR Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:41 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:30 Reconnect Power/Cable! |
03-30-2019, 16:07 | #2 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | emmc test Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A0190613447385637A53273E8A0EF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4G8 [eMMC] : FLASH_CID : 90014A483847346132A53756EFA03573 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x05E7B28E23DD2C979E9BC165152D5B8D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 4355 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , 2a4G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A483847346132A53756EFA03573 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:02:56 Reconnect Power/Cable! |
03-30-2019, 17:03 | #4 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | thanx infinty team problam solve Card found : E8607D5E , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.11 Load : C:\Users\alimobile\Desktop\1\Open-Market-Nokia-1 -FRT-039G-0-00WW-B02_2.nb0 Load Ok! Operation : Write FW [ v1.11 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A483847346132A53756EFA0E873 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847346132A53756EFA03573 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 972CDD2365C19B9E8D5B2D15E306CA42 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000008900000 Erase : 0x000000000ADC0000 : 0x0000000000100000 Erase : 0x000000000B000000 : 0x00000000D4800000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : FRT-0-039G-00WW-1-2-preloader_FRT.bin Flash : FRT-0-039G-00WW-1-2-preloader_FRT.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : FRT-0-039G-00WW-1-2-lk.img Flash : FRT-0-039G-00WW-1-2-lk.img PROCESS : BOOT Unpack : FRT-0-039G-00WW-1-2-boot.img Flash : FRT-0-039G-00WW-1-2-boot.img PROCESS : RECOVERY Unpack : FRT-0-039G-00WW-1-2-recovery.img Flash : FRT-0-039G-00WW-1-2-recovery.img PROCESS : LOGO Unpack : FRT-0-039G-00WW-1-2-logo.bin Flash : FRT-0-039G-00WW-1-2-logo.bin PROCESS : SECRO Unpack : FRT-0-039G-00WW-1-2-secro.img Flash : FRT-0-039G-00WW-1-2-secro.img PROCESS : TEE1 Unpack : FRT-0-039G-00WW-1-2-tee.img Flash : FRT-0-039G-00WW-1-2-tee.img PROCESS : TEE2 Unpack : FRT-0-039G-00WW-1-2-tee.img Flash : FRT-0-039G-00WW-1-2-tee.img PROCESS : ODMDTBO Unpack : FRT-0-039G-00WW-1-2-odmdtbo.img Flash : FRT-0-039G-00WW-1-2-odmdtbo.img PROCESS : SYSTEMINFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : FRT-00WW-001-sutinfo.img Flash : FRT-00WW-001-sutinfo.img PROCESS : CDA Unpack : FRT-00WW-011-cda.img Flash : FRT-00WW-011-cda.img PROCESS : VENDOR Unpack : FRT-0-039G-00WW-1-2-vendor.img Flash : FRT-0-039G-00WW-1-2-vendor.img PROCESS : SYSTEM Unpack : FRT-0-039G-00WW-1-2-system.img Flash : FRT-0-039G-00WW-1-2-system.img PROCESS : CACHE Unpack : FRT-0-039G-00WW-1-2-cache.img Flash : FRT-0-039G-00WW-1-2-cache.img PROCESS : USERDATA Unpack : FRT-0-039G-00WW-1-2-userdata.img Flash : FRT-0-039G-00WW-1-2-userdata.img PMT Update : OK SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:03:32 Reconnect Power/Cable! flash file link https://drive.google.com/uc?id=1XqwE...xport=download |
The Following 4 Users Say Thank You to alimobile279 For This Useful Post: |
08-21-2019, 11:57 | #7 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Unlocking World.
Member: 303336 Status: Offline Sonork: 100.1612298 Thanks Meter: 1,100 | Quote:
