10-08-2015, 15:59 | #1 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | tab innjoo mt6582 restart problem... Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642029B4D07C595211 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
10-08-2015, 22:17 | #4 (permalink) |
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | tab was reading and i took bacup scatter file then i download factory firmware but cant flash because it only flashed on wiselinlk tool,also i cheked battery and without also same error... |
