10-18-2017, 08:52 | #1 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Team Help i Fell Win10 32Bit Error Problem Brand : Symphony ProdName : H300 ProdModel : H300 Device : H300 AndroidVer: 5.1 MTKxCPU : MT6592 MTKxPRJ : ALPS.L1.MP6.V2.15.2_TINNO6592.WET.L_P50 [Read Ok] : preloader_s5420.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 Fatal error, buffer empty! Phone connection lost??? Error while reading block! Something went wrong Read error Operation Failed Elapsed: 00:04:23 Reconnect Power/Cable! |
10-18-2017, 11:13 | #4 (permalink) | |
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
Then i try Read Factory Firmware but Show Error.. i try others 2phone Same Log.. | |
10-18-2017, 11:41 | #6 (permalink) | |
10-18-2017, 12:41 | #7 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Ur phone connection Losing in middle try to charge battery,,,and also use good short Cable and Use direct System usb port not any external hub |
10-18-2017, 14:52 | #8 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | princesaddam Kirumira first check in w10 32bit to read file then give solution it will work after change compability for sometime again give same error when u open again mtk exe dnt know its a bug or ? try same model in w7 it will work w/o any error better use w7 Last edited by mobite; 10-18-2017 at 14:58. |
10-20-2017, 13:18 | #9 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | I faced this problem before i post on forum but i cant get proper solution then i install win 7. http://forum.gsmhosting.com/vbb/f296...-work-2205044/ |
