04-05-2018, 20:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: burkina faso
Member: 457765 Status: Offline Thanks Meter: 77 | teccno camon cm error cannot remove tecno camon cm frp here is log Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
04-05-2018, 22:50 | #3 (permalink) |
Freak Poster Join Date: May 2012 Location: Nigeria
Member: 1765167 Status: Offline Thanks Meter: 71 | http://forum.gsmhosting.com/vbb/f296...-done-2356517/ That's your solution. And please try to use the search option next time. |
