12-02-2017, 05:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MVR
Member: 266180 Status: Offline Thanks Meter: 25 | Tecno c5 hang on smart life here is flash log and below i decide to test the chip (flah ic Ram and other) and result were fine i need help on this one. Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 61 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D53323739F8004255B3CDD6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200F839D6CD7255 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xE12D6E17370F86B784423BDE70A808CC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : h351_a1 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3877 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x0000000102380000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_h351_a1.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0016 Update PMT by user request [SpecOp] : Extend UserArea Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:07:24 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:32 Update Mirror PMT [SpecOp] : Extend UserArea Update Done! Update RomInfo done Done! Elapsed: 00:08:30 Reconnect Power/Cable! log for test below Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 61 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D53323739F8004255B3CDD6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200F839D6CD7255 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xE12D6E17370F86B784423BDE70A808CC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3543 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMS27 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 150100513732534D4200F839D6CD7255 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:02:47 Reconnect Power/Cable! |
