02-06-2017, 18:23 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | tecno C8 mt6735 repair imei Card found : S/N : A6C080ED , v0135 Chinese Miracle II [MTK module] v 1.58 Start at : [06-Feb-17 / 4:46:26 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323238A47E00423FADB5F2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D42007EA4F2B5433F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xDE96B4FF410A8E336D91387E24F26E62 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [06-Feb-17 / 4:46:35 PM] Start at : [06-Feb-17 / 4:53:54 PM] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait...Fin de la discussion any issu to solve this plz? i av tried to connect without boot too |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
02-06-2017, 19:01 | #2 (permalink) |
Freak Poster Join Date: Mar 2012 Location: YAOUNDE (cameroun)
Member: 1732503 Status: Offline Sonork: bip Thanks Meter: 8 | Wait for phone... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Init Service mode failed, something went wrong Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Init Service mode failed, something went wrong Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Init Service mode failed, something went wrong Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : AT+EGMR=0,0 HW : AT+EGMR=0,4 SW : AT+EGMR=0,3 MM : AT+EGMR=0,1 VR : AT+EGMR=0,2 SN : AT+EGMR=0,5 Security Info : IMEI [1] : AT+EGMR=0,7 IMEI [2] : AT+EGMR=0,10 IMEI [3] : AT+EGMR=0,11 IMEI [4] : AT+EGMR=0,12 Read Ok! Update IMEI[1] to : 357262071283803 failed , record not exist or NVRAM damaged! Update IMEI[2] to : 357262071283811 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:05:38 Reconnect Power/Cable! still no ok |
02-06-2017, 19:06 | #3 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Wht abt baseband did u check it plz repair bb with deep fix and try again Sent from my S_plus using Tapatalk | |
