TECNO Camon CX Dead by format with CM2 This Phone Was FRP Locked... I backup this firmware Succesfully But when format it is Dead (NB: It was dead by Another technichian , He make firmware backup First Then he do Format) Here Is Log: Code: Operation : Read Flash [ v1.58 ] Code: Operation : Format FileSystem [ v1.58 ] |
When I want To Flash It again with Backup firmware , CM2 Says Quote:
Take out the battery then reconnect and try again Sent from my SM-N9005 using Tapatalk |
cm2 warned when firmware read useless for write back. now only possibility with official rom. find it. |
yor flash log was say PreLoader : NOT Active [ Erased ] so fast try to reper preloader if not power on remove battery or chack aging |
cm2 can't revive this phone with present version i hope new update do. |
I found A firmware At Google, After flash Still Phone Dead.... Quote:
post results |
Hello Quote:
New Version 1.58 cant write any firmware, But 1.48 writing well... |
AGIN PreLoader : NOT Active [ Erased ] CHACK YOUR FAST LOG FORMAT LOG PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER TRY TO INESTTL 1.58 MTK OR REPER PRELODER I HOPE 1000 DONE OR ON YOUR PAHONE IF NOT DONE CONTECT ME PM |
Hello Quote:
Init Done But Still Dead. Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D42071C259771143D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xC2C76F99E48B13F33E88DE03FB1742C7 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : H501 ProdModel : TECNO Camon CX Device : TECNO-CX AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : CX-H501D1-N-170303V91 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
bahi 1.58 diya bakup writ koren r na holy battery khuly open koren |
Try Sp flash tool Quote:
CM2 take up to 2hr for flash this Phone.... Quote:
this is signed preloder not supported atm wait for next updated otherwise you can use official rom and flash tool. |
