Old 07-27-2017, 11:24   #1 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
Exclamation TECNO Camon CX Dead by format with CM2
This Phone Was FRP Locked...
I backup this firmware Succesfully But when format it is Dead
(NB: It was dead by Another technichian , He make firmware backup First Then he do Format)
Here Is Log:
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0002
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1E
[eMMC] : FLASH_CID : 150100524531424D42071C259771143D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xC2C76F99E48B13F33E88DE03FB1742C7
INT RAM    : 0x00000000
EXT RAM    : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : TECNO
ProdName  : H501
ProdModel : TECNO Camon CX
Device    : TECNO-CX
AndroidVer: 7.0
MTKxCPU   : MT6755
MTKxPRJ   : CX-H501D1-N-170405V107
[Read Ok] : preloader_rlk6750_65_n.bin
[Read Ok] : recovery.img
[Read Ok] : md1img.img
[Read Ok] : md1dsp.img
[Read Ok] : md1arm7.img
[Read Ok] : md3img.img
[Read Ok] : lk.bin
[Read Ok] : lk2.bin
[Read Ok] : boot.img
[Read Ok] : logo.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6755 / V1.1.2 / rlk6750_65_n / EMMC
Android Info saved
HWConfig Info saved
FW Size : 4281 MiB
Scatter saved to : F:\MT6755__TECNO__TECNO_Camon_CX__TECNO-CX__7.0__CX-H501D1-N-170405V107\
All done!
Here Is Format Log:
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear PVL ( PrivacyLock )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Old 07-27-2017, 11:26   #2 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
When I want To Flash It again with Backup firmware , CM2 Says
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Connection agent : BROM
DRAM configured from ScatFW!
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
ScatCFG : BaseBand : MT6755 , Project : rlk6750_65_n , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
M67BL : Check eMMC compatibility
M67BL : eMMC supported by BootLoader!
Selected forced PMT update
Build new PMT ...
Update Primary ...
Main PMT update failed!
Operation Failed
Elapsed: 00:00:13
Old 07-27-2017, 11:31   #3 (permalink)
Member: 2659717
Thanks Meter: 463
Take out the battery then reconnect and try again
Sent from my SM-N9005 using Tapatalk
Old 07-27-2017, 12:13   #4 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,247
cm2 warned when firmware read useless for write back.
now only possibility with official rom. find it.
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 07-27-2017, 12:25   #5 (permalink)
Abul Basher's Avatar
Member: 1675107
Sonork: n/a
Thanks Meter: 120
======= Flash
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DAgent configured successfully]
yor flash log was say PreLoader : NOT Active [ Erased ]
so fast try to reper preloader if not power on remove battery or chack aging
Old 07-27-2017, 13:56   #6 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 119
cm2 can't revive this phone with present version i hope new update do.
Old 07-27-2017, 14:51   #7 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
I found A firmware At Google, After flash Still Phone Dead....
Operation : Flash [ v1.48 ]
======= Flash
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0002
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1616.01.01
DEV RID : 0x1D2D541E950FBCA79700B5C8950FBCA7
INT RAM : 0x00040000
Boot Ok!
Setting : HW verify : Disabled
M67BL : Skip HW_COMPATIBILITY_CHECK by User request!
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Total blocks to Erase : 5
Erase : 0x0000000000008000-0x0000000001A80000
Erase : 0x0000000001BC8000-0x0000000004000000
Erase : 0x0000000007000000-0x0000000001000000
Erase : 0x0000000008300000-0x0000000002400000
Erase : 0x000000000AC00000-0x00000003981FBE00
Flash Erase Done, time used : 00:00:02
Processing : Writing all Flash Files
Flash Partition : PRELOADER
Flash PLC
Image Flash Ok
Flash Partition : RECOVERY
Image Flash Ok
Flash Partition : MD1IMG
Image Flash Ok
Flash Partition : MD1DSP
Image Flash Ok
Flash Partition : MD1ARM7
Image Flash Ok
Flash Partition : MD3IMG
Image Flash Ok
Flash Partition : LK
Image Flash Ok
Flash Partition : LK2
Image Flash Ok
Flash Partition : BOOT
Image Flash Ok
Flash Partition : LOGO
Image Flash Ok
Flash Partition : TEE1
Image Flash Ok
Flash Partition : TEE2
Image Flash Ok
Flash Partition : SECRO
Image Flash Ok
Flash Partition : SYSTEM
Image Flash Ok
Flash Partition : CACHE
Image Flash Ok
Flash Partition : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:02:26
Done!
Elapsed: 00:02:37
Init Preloader:
Start at : [7/27/2017 / 6:45:07 PM]
Operation : Init Preloader [ v1.48 ]
Supported HW by Preloader :
FlashID [0] CID : 150100525831424D42 , Name : RX1BMB , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 150100524531424D42 , Name : RE1BMB , Vendor : 15 , [SAMSUNG]
FlashID [2] CID : 90014A484147346132 , Name : HAG4a2 , Vendor : 90 , [HYNIX]
FlashID [3] CID : 150100514531334D42 , Name : QE13MB , Vendor : 15 , [SAMSUNG]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
BL : Storage supported by BootLoader!
Sending BootLoader ...
Init BL #1 : 0001
Init BL #2 : 0001
PartTable Init Ok , Count : 1D
All Done
Done!
Elapsed: 00:00:10
Read Info Again:
Operation : Check / Read Info [ v1.48 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
[AP] : Initial info read Ok!
Brand : TECNO
ProdName : H501
Device : TECNO-CX
AndroidVer: 7.0
MTKxCPU : MT6755
MTKxPRJ : CX-H501D1-N-170303V91
Done!
Elapsed: 00:00:06
No Response From Infinity Team Yet...
Old 07-27-2017, 16:02   #8 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,355
Init Preloader:
Read Info Again:
Bro,you are using very old cm2 software,anyway flash using latest SPF Tool using factory firmware.
post results
Old 07-27-2017, 16:51   #9 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
Hello
post results
New Version 1.58 cant write any firmware,
But 1.48 writing well...
Old 07-27-2017, 16:56   #10 (permalink)
Member: 1675107
Sonork: n/a
Thanks Meter: 120
AGIN PreLoader : NOT Active [ Erased ]
CHACK YOUR FAST LOG FORMAT LOG
TRY TO INESTTL 1.58 MTK OR REPER PRELODER I HOPE 1000 DONE OR ON YOUR PAHONE
IF NOT DONE CONTECT ME PM
Old 07-27-2017, 17:14   #11 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
Unhappy Hello
Just init preloader ,
Init Done But Still Dead.
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
Boot Ok!
Brand : TECNO
ProdName : H501
Device : TECNO-CX
AndroidVer: 7.0
MTKxCPU : MT6755
Done!
Elapsed: 00:00:09
Old 07-27-2017, 17:16   #12 (permalink)
Member: 1675107
Sonork: n/a
Thanks Meter: 120
bahi 1.58 diya bakup writ koren r na holy battery khuly open koren
Old 07-28-2017, 05:38   #13 (permalink)
Member: 2043843
Thanks Meter: 39
Try Sp flash tool
Flash with sp flash tool
Old 07-28-2017, 06:12   #14 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 640
CM2 take up to 2hr for flash this Phone....
Start at : [7/27/2017 / 11:10:42 PM]
======= Flash
Wait for phone...
Phone found! [ 29 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Build new PMT ...
Update Primary ...
Update Mirror ...
PMT update Ok!
M67BL : Flash Erase
Flash Erase Done, time used : 00:00:01
Flash PLC
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Image Flash Ok
Flash Write Done, time used : 02:04:41
Done!
Elapsed: 02:04:57
Finish at : [7/28/2017 / 1:15:40 AM]
No response from infinity Team yet, 2 days passed....
Old 07-28-2017, 06:16   #15 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 945
this is signed preloder not supported atm wait for next updated otherwise you can use official rom and flash tool.
The Following 3 Users Say Thank You to kothamamun For This Useful Post:
Page generated in 0.44345 seconds with 7 queries
