06-08-2017, 06:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: NIGERIA
Member: 676315 Status: Offline Thanks Meter: 120 | tecno cx dead with cm2 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : TECNO Device Model : TECNO-CX Device CPU : MT6755 Device IntName : H501 Device Version : 7.0 Device Compile : 4/5/2017 3:19:31 PM Device Project : CX-H501D1-N-170405V107 Device ExtInfo : TECNO Camon CX |
The Following User Says Thank You to wisdom001 For This Useful Post: |
06-08-2017, 08:05 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
06-08-2017, 08:57 | #4 (permalink) |
Freak Poster Join Date: Dec 2015 Location: ivory coast
Member: 2506976 Status: Offline Thanks Meter: 16 | That is right nck box Android is the Best for flashing MTK firmware Envoyé de mon Infinix NOTE 3 en utilisant Tapatalk |
The Following 3 Users Say Thank You to tyno For This Useful Post: |
06-08-2017, 10:07 | #5 (permalink) |
Member: 676315 Status: Offline Thanks Meter: 120 | sptool can't flash the back up of tecno cx with cm2 very strange about cm2, can anybody upload the file for me and which tool to back up the phone properly?. |
06-13-2017, 09:17 | #6 (permalink) | |
Junior Member Join Date: Oct 2015
Member: 2477859 Status: Offline Thanks Meter: 1 | Quote:
Sent from my TECNO Camon CX using Tapatalk | |
The Following User Says Thank You to peterosoro For This Useful Post: |
06-13-2017, 12:15 | #7 (permalink) |
Member: 676315 Status: Offline Thanks Meter: 120 | please help me bro i really need the file here is the recovery and boot https://www.4shared.com/rar/E3DyflTN...RECOVERY.html? |
06-21-2017, 17:51 | #8 (permalink) |
Member: 2477859 Status: Offline Thanks Meter: 1 | Thanks for the stock boot and recovery,it helped me get TWRP and root I'll upload a nandroid backup i made with TWRP when I get data in less than 24 hours,meanwhile unlock your bootloader Sent from my TECNO Camon CX using Tapatalk |
06-25-2017, 22:16 | #9 (permalink) |
Member: 676315 Status: Offline Thanks Meter: 120 | readed working phone but flashed but the problem the same only vibrate it seems cm2 has problem with android 7 and sptol error with scatter file readed by cm2 and spff still showing error please help infinity team Start at : [6/25/2017 / 7:50:00 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phoned BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D42071E4E9BB73493 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2A722EAA6D50C56AD841FD8CB28F8F45 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : rlk6750_65_n , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001A80000 Erase : 0x0000000001BC8000-0x0000000004000000 Erase : 0x0000000007000000-0x0000000001000000 Erase : 0x0000000008300000-0x0000000002400000 Erase : 0x000000000AC00000-0x00000003981FBE00 Flash Erase Done, time used : 00:00:02 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Ok Flash Partition : MD1IMG Image Flash Ok Flash Partition : MD1DSP Image Flash Ok Flash Partition : MD1ARM7 Image Flash Ok Flash Partition : MD3IMG Image Flash Ok Flash Partition : LK Image Flash Ok Flash Partition : LK2 Image Flash Ok Flash Partition : BOOT Image Flash Ok Flash Partition : LOGO Image Flash Ok Flash Partition : TEE1 Image Flash Ok Flash Partition : TEE2 Image Flash Ok Flash Partition : SECRO Image Flash Ok Flash Partition : SYSTEM Image Flash Ok Flash Partition : CACHE Image Flash Ok Flash Partition : USERDATA Image Flash Ok Flash Write Done, time used : 00:02:12 |
06-25-2017, 22:43 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. We almost finished MTK module rebuild. Hope it will fix all issues. If you have a chance to get factory FW - try flash it. Device should be fixed after. |
06-26-2017, 15:19 | #12 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | are u sure they are same build number....which state are u exactly in Nigeria if problem continues, flash only the logo.bin or preloader and atleast to give the owner assurance... |
07-11-2017, 12:30 | #13 (permalink) | |
But you can download TWRP from hovatek and make a nandroid backup of a working phone System and boot And then try to write recovery image using spft now that you have a scatter from the backup you made if it boots recovery you can restore the backup Sent from my ONE PLUS 5 using Tapatalk | |
