Old 10-17-2018, 15:22   #1 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
Tecno DP7CPRO stop coming on after box disconnect during flashing, how to solve it?
I did this "Tecno DP7CPRO" SmartAV and it went well, then as I am flashing it, my laptop shift and the box disconnected then the flashing stopped and now the phone is not coming on again and could not continue flashing, please how will I solve the problem?
Below are the logs;
Identify log;
Card found : S/N : B25B7C49 , v0136
Start at : [10/17/2018 / 2:04:28 PM]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 700100563130303136500305B8AA7305
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 61001
[eMMC] : FLASH_CID : 700100563130303136500305B8AA7305
[eMMC] : FLASH_LEN : 0x0000000386000000
[eMMC] : FLASH_UCP : 14432 MiB [eMMC 16 GiB]
DEV RID : 0xCA0D485B7975960DD1E062CC65C7BB80
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TECNO
ProdName : DP7CPRO
ProdModel : TECNO DP7CPRO
Device : DP7CPRO
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_HTT8321.EMMC_P21
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Finish at : [10/17/2018 / 2:04:38 PM]
SmartAV log;
Start at : [10/17/2018 / 2:04:53 PM]
Operation : Remove Viruses [SmartAV] [ v1.58 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 2
Removing infected files and scripts ...
SmartAV Report : Removed 2 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:00:38
Finish at : [10/17/2018 / 2:05:32 PM]
Flashing logs that stopped;
Scatter Load Ok , BaseBand : MT6580 , Project : htt8321_emmc , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : TECNO
Device Model : DP7CPRO
Device CPU : MT6580
Device IntName : DP7CPRO
Device Version : 5.1
Device Compile : 3/25/2016 10:53:45 AM
Device Project : ALPS.L1.MP6.V2_HTT8321.EMMC_P21
Device ExtInfo : TECNO DP7CPRO
Ready to Flash!
Start at : [10/17/2018 / 2:07:44 PM]
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : htt8321_emmc , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Only one records found, and determined as universal
BL : BatteryLevel : 4130 mV
BL : BatteryLevel Ok
Backup enabled!
Backup saved : Backup\Flash\700100563130303136500305B8AA7305\
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x000000037FEE0000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_htt8321_emmc.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Write Error , code 0x001! Something went wrong!
Operation Failed
Now the error is having;
Device CPU : MT6580
Ready to Flash!
Start at : [10/17/2018 / 2:18:40 PM]
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xC40B0000
EMICFG_RET_FAILED
CodeDefine : DA_DEVICE_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:20
Finish at : [10/17/2018 / 2:18:59 PM]
Please someone help me out on how to solve this error!
Thanks!
Old 10-17-2018, 16:15   #2 (permalink)
Member: 576282
Thanks Meter: 145
Below are the logs;
Identify log;
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : TECNO
ProdName : DP7CPRO
Device : DP7CPRO
AndroidVer: 5.1
MTKxCPU : MT6580
Done!
Elapsed: 00:00:09
SmartAV log;
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Done!
Done!
Elapsed: 00:00:38
Device CPU : MT6580
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup enabled!
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Operation Failed
Device CPU : MT6580
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
EMICFG_RET_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:20
Thanks!
Please somebody help me out on this!
Can heat the Mediatek chip solve this error?
Old 10-17-2018, 18:35   #3 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,639
Try disconnect battery for 10 minutes, them repeat operation holding Vol+& - or hold One by one vol + or Vol -
Page generated in 0.23786 seconds with 8 queries
