Old 06-29-2019, 15:17   #1 (permalink)
Member: 974244
Thanks Meter: 50
Tecno F1 imei could not be changed by cm2mt2.06 ,even cm2mt1.58
Card found : S/N : E3B1B8F3 , v0137
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 148 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019061324734BA360111891A6974
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A4834473261110136BA74694289
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x9BE78CE1783D96233A74FB9D68EBA4AF
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 356543598786571
IMEI [01] : 356454365623411
Set IMEI [00] : 356545435434323
Set IMEI [01] : 356546765343233
Prepare finished. Security check required!
Wait for phone...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Reconnect Power/Cable!
Old 06-29-2019, 15:19   #2 (permalink)
Member: 974244
Thanks Meter: 50
Tecno B1P imei not changed by cm2mt2.06
Card found : E3B1B8F3 , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v46104 Ok!
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Mobistel PreLoader USB VCOM Port (COM148)
MODE : PRELOADER PORT
PORT : 148
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : TECNO : B1P | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC_AC.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001704545414DB21520382F367B17
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 700100464D414545382015B2177B362F
EMMC: VEN : KINGSTON | OEM : 01 | DEV : FMAEE8
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A8000000 [ 14.63 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 82A0FC40C007EA4A402DF0143C5DF51B
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Done!
Elapsed: 00:00:21
Operation : Reset Settings/Format FS [ v2.06 ]
PORT : 148
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:23
PORT : 148
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Done!
Elapsed: 00:00:33
PORT : 148
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:50
PORT : 148
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:01:17
Operation : Repair Security [ v2.06 ]
PORT : 148
BROM : Init BROM
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Old 06-29-2019, 15:21   #3 (permalink)
Member: 974244
Thanks Meter: 50
Tecno F2 lite imei not fised by cm2mt2.06
Host not found.
PTFN : Mobistel PreLoader USB VCOM Port (COM142)
PORT : 142
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
TYPE : MODERN RAPHAEL
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : MTK_AllInOne_DA_SP.bin
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00040000 [ 256.00 KB ]
EMMC: 150100464E36324D4203D82296EA4563
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
EMMC:
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : CF68A9DDBD826B6D97BD0A39DF6F668C
Boot done!
Done!
Elapsed: 00:00:19
PORT : 142
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
NVRAM check : Passed!
NVRAM condition BAD! Impossible to continue!
Done!
Elapsed: 00:00:25
PORT : 142
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Done!
Elapsed: 00:00:25
PORT : 142
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Done!
Elapsed: 00:00:20
PORT : 142
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Done!
Elapsed: 00:00:24
Page generated in 0.23104 seconds with 9 queries
