Old 07-13-2018, 19:44   #1 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
TECNO F3 STUCK ON logo AFTER CACHE FORMAT
TECNO F3 after format stuck on logo. I reflash with the backup flash file it same.
Bro help me with good flash file.
Old 07-13-2018, 19:46   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
post full log from infinity cm2
Old 07-13-2018, 19:47   #3 (permalink)
Member: 2500215
Thanks Meter: 417
Check if you can get to recovery mode. If no command or api error, then you are screwed up. Only one way
Old 07-14-2018, 12:52   #4 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-11-09.13:12_393798
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9C
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E36324D4203792E6851B47B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM26N
[eMMC] : FLASH_CID : 150100464E36324D4203792E6851B47B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xA18F895C883F96E1D1FCB39FFB3BA2EF
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TECNO
ProdName : H8022
ProdModel : TECNO F3
Device : TECNO-F3
AndroidVer: 7.0
MTKxCPU : MT6580
MTKxPRJ : F3-H8022AC-N-180228V73
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
make test log
Processing Miscellaneous test
MSC : BatteryLevel : 4035 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BM26N , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 150100464E36324D4203792E6851B47B
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:02:35
Old 07-14-2018, 12:54   #5 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
how to take off on the cross of infinity. bro.
Old 07-14-2018, 20:00   #6 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Any solution for me bro. Custom kill me
Old 07-15-2018, 11:37   #7 (permalink)
Member: 2500215
Thanks Meter: 417
If you reboot to recovery mode but you see error such as no command or api support error.
There is no way to solve it except a wipe that triggers the device to start erase command.
That's why I am pleading for CM2 team to implement the kind of wipe function Inferno had.
It has been the only tool fixing such format error in these devices.
From Infinix hot 5 and above
All recent Tecno devices especially Tecno LA6.
I have mentioned this since last year. But no one is seeing it useful.
I can tell how many people I have helped reactivate inferno from their trash bin because of one single function.
Please team. Put this as test, or provide your special wipe function that can solve this.
These regular wipe makes these devices hang on logo even after using factory file
The Following User Says Thank You to Southsider2009 For This Useful Post:
Old 07-15-2018, 14:12   #8 (permalink)
Member: 2521913
Thanks Meter: 251
Bros this file is available Google it you most find it I solve my own
Old 08-08-2018, 14:52   #9 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
Bro share the, I try several rom but not success.
Old 08-08-2018, 15:05   #10 (permalink)
Member: 1677653
Thanks Meter: 2,769
Don't waste your time, you need signed firmware to bring your phone back Alive
Old 08-08-2018, 16:18   #11 (permalink)
Registered User
Member: 1040340
Thanks Meter: 58
how can get it? BAD SEASON WITH TECNO
Old 08-08-2018, 16:23   #12 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
https://mega.nz/#!seZCVIAB!6PFUspska...q734V3CZj0OvkU
The Following 2 Users Say Thank You to akhil_bbsr For This Useful Post:
Old 09-21-2018, 11:31   #13 (permalink)
..::Qus::..'s Avatar
Member: 2335787
Thanks Meter: 149
No tension just flash this file
your Problem 100% will be solve
Collected Customer Care
tecno f3 supported api 3
Tecno F3 Hang logo Firmware
TECNO F3 Official Flash File
Download
The Following 4 Users Say Thank You to ..::Qus::.. For This Useful Post:
Old 09-21-2018, 12:08   #14 (permalink)
Member: 1677653
Thanks Meter: 2,769
Download
Do u know techno official website to download factory/signed firmware? If yes please share link or pm
Old 09-21-2018, 12:51   #15 (permalink)
Member: 2335787
Thanks Meter: 149
Originally Posted by yusuf lawal View Post
do u know techno official website to download factory/signed firmware? If yes please share link or pm
sorry brother i dont know
The Following User Says Thank You to ..::Qus::.. For This Useful Post:
Page generated in 0.33200 seconds with 8 queries
