08-06-2018, 12:05 | #1 (permalink) |
Insane Poster Join Date: Nov 2017 Location: Arab Country Age: 28
Member: 2777551 Status: Offline Thanks Meter: 22 | Tecno In5 Frp Failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Show THis Error PLz Help Team |
The Following User Says Thank You to Odin01 For This Useful Post: |
08-07-2018, 08:20 | #7 (permalink) |
Member: 2777551 Status: Offline Thanks Meter: 22 | Try But Same Error Card found : S/N : 5F9D41A7 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017/12/28.11:39_396299 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
08-07-2018, 08:28 | #8 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Find your solution here http://forum.gsmhosting.com/vbb/13174409-post133.html |
08-08-2018, 03:34 | #10 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
don't hold boot keys | |
