04-15-2019, 14:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Tecno-Infinix-Itel DA+auth files in infinity support free for all DEAD Solution enjoy |
The Following 4 Users Say Thank You to rebainoor For This Useful Post: |
04-15-2019, 19:54 | #7 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,104 | For dead boot (Brom mode) for exp : tecno mobile you need use files (DA+auth) in folder : [v3.3001.2018-11-07.2357_458956] and select auth suitable with your CPU and dont forget to use original signed firmware for your Model and your region |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
04-16-2019, 10:49 | #9 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,104 | What file are you downloading Folder contain auth files is : v3.3001.2018-11-07.2357_458956 If you dont know what auth file for your mobile try one by one MT6737=MT6735 Last edited by rebainoor; 04-16-2019 at 10:54. |
04-16-2019, 11:03 | #10 (permalink) |
Freak Poster Join Date: Mar 2011 Location: lagos nigeria
Member: 1535920 Status: Offline Thanks Meter: 31 | thank you boss though the phone has not booted on but its now flashing. i think i would need to look for right sign file. below is my operation log; Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :11 [FL] : Set : preloader_rlk6737t_65_n.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x1122C4BB4 [ 4.28 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514536334D42031459D3BFEFCF DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D42031459D3BFC4CF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 160762E15F3F3690EC1FA99F912DBC7D STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x00000003A1080000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : SECRO SecInit : TEE1 SecInit : TEE2 SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM. once again thanks boss you have given my tecno ca6 phone hope |
04-16-2019, 11:10 | #11 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,104 | Yes you need only to write correct signed firmware for your tecno CA6 you Can search it in https://androidhost.ru/search.html |
04-16-2019, 15:06 | #12 (permalink) |
Member: 1535920 Status: Offline Thanks Meter: 31 | thank you thank you thank you thank you for this post my tecno camon cm is back alive after one year and some month. i just cant thank you enough. thank you big bozz |
The Following 3 Users Say Thank You to kazzy4real For This Useful Post: |
04-16-2019, 16:16 | #14 (permalink) | |
Member: 1535920 Status: Offline Thanks Meter: 31 | Quote:
Operation : Identify [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM19) MODE : BOOTROM PORT : 19 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! but today with auth file and the da you provide, this is my success story; Operation : Write Flash [ v2.05 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :11 [FL] : Set : preloader_rlk6737t_65_n.bin [FL] : Set : lk-sign.bin [FL] : Set : boot-sign.img [FL] : Set : recovery-sign.img [FL] : Set : logo-sign.bin [FL] : Set : secro-sign.img [FL] : Set : trustzone-sign.bin [FL] : Set : trustzone-sign.bin [FL] : Set : system-sign.img [FL] : Set : cache-sign.img [FL] : Set : userdata-sign.img [FL] : Total size : 0x1122C4BB4 [ 4.28 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514536334D42031459D3BFEFCF DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514536334D42031459D3BFC4CF EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 160762E15F3F3690EC1FA99F912DBC7D STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x00000003A1080000 [FL] : RePartition [FL] : RePartition Ok! SecInit : LK SecInit : BOOT SecInit : RECOVERY SecInit : LOGO SecInit : SECRO SecInit : TEE1 SecInit : TEE2 SecInit : SYSTEM SecInit : CACHE SecInit : USERDATA [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : WRITE INFO : OK SEC_DL : True (CUST) SEC_DL : SECURE USB DL ENABLED SEC_ID : 0x63616334633434326462376361623562 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:06:29 | |
04-16-2019, 16:24 | #15 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,104 | you can read info identify and connect your mobile in BROM mode by pressing VOL keys and use auth suitable auth file to see a result Last edited by rebainoor; 04-16-2019 at 16:32. |
