Old 07-13-2019, 07:48   #1 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
tecno k7 which any change after flash
hi
Tecno k7 which any change after flash or after flash all user data is there. what option of infinix box can solve it . which infinity program option can fix this problem, i thought rooting might be a solution but i would like to know if anyone has ever done it. thank
Old 07-13-2019, 09:00   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
(1)what is problem with device
(2)post operation log from cm2
(3)read emmc test from cm2 mtk v1.58 and post log
Old 07-14-2019, 21:47   #3 (permalink)
roni2's Avatar
Member: 862014
Sonork: 100.1608307
Thanks Meter: 64
this is ic test:
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2018-04-25.11:26_437806
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9C
NAND Flash : NOT INSTALLED
eMMC Flash : 700100454841454538011550543D4549
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 8EEAH
[eMMC] : FLASH_CID : 700100454841454538011550543D4549
[eMMC] : FLASH_LEN : 0x0000000390000000
[eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB]
DEV RID : 0x5165B37FDC03E072F168166194BE0DB4
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [KINGSTON] , 8EEAH , 0x390000000 , 14592 MiB
[eMMC] : CID : 700100454841454538011550543D4549
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:00:43
Reconnect Power/Cable!
i don t know and it only tecno k7 which have the pbm. i have 4 with the same pbm. it refuse to root, bcz bootload refuse to unlock
Old 07-14-2019, 22:07   #4 (permalink)
Member: 1677653
Thanks Meter: 2,769
But next time always use default DA for this kind of phone..
Page generated in 0.31072 seconds with 8 queries
