Old 12-11-2018, 19:26   #1 (permalink)
pastday's Avatar
Member: 2588864
Thanks Meter: 62
lenovo tab TB3-710F problem???
hi infinity team i have problem with lenovo tab TB3-710F that each time try to open play store still give me this - app is not installed- i flash it and formate many time it work for few minute then give that message again and also at the top of screen give this message app permission management is closed, ....i make memory test here is the log
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BB_CPU_NME : [MediaTek] MT8127_S00
BB_CPU_EXT : 0xCA03 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8D
NAND Flash : NOT INSTALLED
eMMC Flash : 15010038474D45345201D698EE544457
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R4EMG
[eMMC] : FLASH_CID : 15010038474D45345201D698EE544457
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xA9A792929D526B6A1E8184D0B9F7739B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery )
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , R4EMG , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 15010038474D45345201D698EE544457
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:03:02
Reconnect Power/Cable!
please help ........thanks
The Following User Says Thank You to pastday For This Useful Post:
Old 12-11-2018, 20:10   #2 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 80
It's bootloader is unlocked?
Old 12-11-2018, 20:31   #3 (permalink)
pastday's Avatar
Member: 2588864
Thanks Meter: 62
no i did not check bootloader unlocked? so bro what should i do unlock bootloader to solve this...........thanks
Old 12-11-2018, 20:46   #4 (permalink)
pastday's Avatar
Member: 2588864
Thanks Meter: 62
mr bhalaygilani do have any idea how to solve this
Old 12-11-2018, 21:37   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make sure about FW is good and factory or from trusted source.
Make sure about after FactoryReset device exactly restart as clean, not just boot to home screen.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-11-2018, 23:33   #6 (permalink)
pastday's Avatar
Member: 2588864
Thanks Meter: 62
Thanks...when i finish software or make full factory to the tab it is always takes about 10 minute to reach the home menue..so may be the reson for my problem in google play not installed related to hardware problem??...thanks in advance
Old 12-12-2018, 03:55   #7 (permalink)
Member: 1647864
Thanks Meter: 80
Dear you must try to make a factory reset from settings after flash. Your device may be rooted, check root status, make bootloader locked and post result here... Also make a request to JayDi sir, he may help in a better way...
The Following User Says Thank You to bhalaygilani For This Useful Post:
Page generated in 0.17392 seconds with 9 queries
