07-18-2018, 10:25 | #4 (permalink) | |
Junior Member Join Date: Jan 2015 Location: Nigeria
Member: 2336625 Status: Offline Thanks Meter: 6 | Quote:
The Following User Says Thank You to Hovatek For This Useful Post: |
08-23-2018, 02:51 | #8 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Whole thread without a single log What guys you doing spamming or increase post counting? |
The Following 2 Users Say Thank You to kamal_singla For This Useful Post: |
09-02-2018, 18:58 | #10 (permalink) |
Crazy Poster Join Date: Sep 2007
Member: 587029 Status: Offline Thanks Meter: 8 | la7 dead can't flash ask for auth Card found : xxxxxxx , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Created by Infinity-Box (c) 2018 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : O11019 Display ID : LA7-H393A-O-180608V128 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 1528431235 Product Brand : TECNO Product Manfct : TECNO MOBILE LIMITED Product Model : TECNO LA7 Product Device : TECNO-LA7 Product Name : H393 Product Info : TECNO-LA7 Product Board : la7_h393 Board Platform : mt6739 Preloader [HW DEV] Info : EMI : DEV : EMI : SRC : EMI : CNT : 0000 Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :19 [FL] : Set : preloader_la7_h393.bin [FL] : Set : preloader_la7_h393.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : odmdtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x7639E0AC [ 1.85 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM90) MODE : BOOTROM PORT : 90 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+SEL BROM : BOOTROM MODE : TECNO : Tecno LA7 DA | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : SLA AUTH or AUTH required! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable |
09-07-2018, 04:44 | #11 (permalink) | |
Insane Poster Join Date: Nov 2015 Location: Nigeria
Member: 2491104 Status: Offline Thanks Meter: 15 | Quote:
10-06-2018, 18:55 | #12 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
Is not true my dear and is mistake I make on the file I downloaded from your site that kills my own TECNO LA7, why are you giving stock firmwares without scatter files, many of your files kills phone. @All, check out here and you will see how to solve this error, all we need is either auth file or emmc reprogramming. Please if any one finds solution lets the person share please! Thanks! http://forum.gsmhosting.com/vbb/f296...l#post13353710 | |
10-14-2018, 22:16 | #15 (permalink) | ||
Member: 2336625 Status: Offline Thanks Meter: 6 | @lionfinger2007 , you've got quite a number of things sideways in your brief comment but I'll try to keep this as short as possible and hope you're open to see things differently. The question began as Quote:
Two things (I trust you're familiar with both) 1. A Mediatek device could go dead when a flashing attempt is interrupted by an error. LA7 has secure boot and requires a DA file. So getting a Secure Boot error (when flashing without a da file) could cause some phones to go dead due to the error message 2. Some SP flash tool errors contain the word "Auth" but their fixes range from using the right firmware to getting a DA file. As a result of the OP not providing sufficient info, its best to start with safe assumptions and adjust as more info (from OP or tests) flows in. I suspect the OP actually got the DA then formatted the phone. This causes flash tools to request an Auth file. You don't format a Secure Boot MTK phone. Take a look at https://journal.hovatek.com/so-whats...-and-da-files/ Now, to address some points you raised Quote:
This is a fallacy of hasty generalization. How many scatter format firmware have you downloaded from our website without it containing or us providing a scatter file? Even our LA7 firmware page (Individual files) contains a scatter file if you look . They are called scatter format firmware because they include scatter files right? We have the largest online collection of Tecno firmware and go great lengths to list the build numbers of the firmware we list (that's easy for all to see). If you go flashing a firmware which isn't for your build number or do something wrong then the fault isn't from the firmware is it? T I get your frustration but lets separate emotions from facts OK? Your phone asking for Auth is likely because you formatted a secure boot MTK device. Formatting of course leaves your phone dead. That's a predictable outcome. On a lighter note, the Auth error isn't the end of the road, there are fixes only if you have the right files / tools. | ||
The Following 3 Users Say Thank You to Hovatek For This Useful Post: |
