02-19-2018, 12:24 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Tecno n5s no imei baseband unknown how to repair? |
02-22-2018, 09:19 | #2 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | problem solved i flashed with this firmware ([romshillzz] N5S-QL610-MB-L-20150820) and repair imei whith cm2: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00009601 MODHW : 0000100C BUILD : 8909_r01135.2_20150720 RTIME : Aug 20 201518:50:46 BTIME : Jul 13 201508:00:00 DEVST : 8909.gen Update IMEI[1] : 359616046229779 Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
03-10-2018, 18:51 | #4 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | as the soft say: 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct you need to root your phone firsi use iroot or kingo for root then enable diagport look at the soft you will find diag enable button and only then you will be able to repair imei |
