Old 10-21-2017, 10:29   #1 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Tecno N8 unlock network
Hi there i have Tecno N8 with network lock i try to unlock but says device not locked. i realize the bootloader was locked so i unlock it but still failed to unlock. can please team help on this.... below are the logs:....
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 4500017045433848B50C01380F5144E1
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 8EC8H
[eMMC] : FLASH_CID : 700100454838434538010CB5E144C30F
[eMMC] : FLASH_LEN : 0x00000001C8000000
[eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB]
DEV RID : 0xE12D6E17D1E6BC1EC23D8B75FCA2A325
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Lock Status : Not Locked!
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Any one plz help
The Following 2 Users Say Thank You to ntothel For This Useful Post:
Old 10-21-2017, 10:43   #2 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Any one who can help plz
Old 10-21-2017, 11:00   #3 (permalink)
2201's Avatar
Member: 2639338
Thanks Meter: 133
Tried many times with cm2 but got same error that device not locked, other tools unlocked it so dont waste ur time trying unlocking N8 with cm2 simply because the phone is not supported by infinity... Find another tool
Old 10-21-2017, 11:41   #4 (permalink)
Member: 2642393
Thanks Meter: 34
It is MT6580 not MT6737. Choose the correct CPU from Infinity interface.
Old 10-21-2017, 11:54   #5 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
1-Read codes methods works
2-Backup NV first,FIX baseband with DEEP-FIX Ticked,after switch on phone Fully.
Now switch off ,then UNLOCK AGAIN
Results ??
Old 10-21-2017, 13:34   #6 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Thanks all.. i flash it with unlocked firmware by sp tool and set is done.
Old 09-19-2018, 22:25   #7 (permalink)
Member: 2392555
please sir can you send me the link to download that file
Old 09-19-2018, 22:49   #8 (permalink)
Crazy Poster
Member: 2397842
Thanks Meter: 18
model and version........
Page generated in 0.18161 seconds with 9 queries
