08-08-2018, 14:49 | #1 (permalink) |
Registered User Join Date: May 2009 Location: BONOUA - Ivory Coast
Member: 1040340 Status: Offline Thanks Meter: 58 | Tecno p904 mt6737m not power after flash cm2 flash log; 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017046454148B31A01413F471F39 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , AFEAH [eMMC] : FLASH_CID : 700100454841454641011AB3391F343F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0xA18F895CA3620A97A2FBC0279580BD20 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : p904_rlk8735b_tb_tst_n , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3846 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004D80000 Erase : 0x0000000006B00000-0x0000000388480000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_p904_rlk8735b_tb_tst_n.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:04 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:58 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:24 Reconnect Power/Cable! identify log: Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017046454148B31A01413F471F39 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , AFEAH [eMMC] : FLASH_CID : 700100454841454641011AB3391F343F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0xA18F895CA3620A97A2FBC0279580BD20 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : PA05 ProdModel : TECNO P904 Device : TECNO-P904 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : P904-PA05A-N-170714V30 SECURITY : IMEI_SW [1] : 358940081254729 IMEI_SW [2] : 358940081254737 BTMAC Addr : 04946BFFA936 WiFi MAC : 04946BFFE112 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
