03-04-2017, 18:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Tecno T465 Bin file need Thankxx |
The Following User Says Thank You to Kirumira For This Useful Post: |
11-01-2017, 09:56 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | TECNO-T465 nfo Connected to Phone. CPU: MT6260_S0000 Ver: CB00 md: 8000 Downloading Boot7 ... Nor / SF Flash Type: [GIGA] GD25LQ64 Nor Flash Code: 00C80060 (00170000) Nor / SF Flash Size: 0x800000 Hex Bytes INT / EXT RAM Size: 0x0 / 0x0 Reading infr (Nor) ... The phone information: UL251_T465_EG_PCB01_GPRS_MT6260_S00.T465UL251-AF-EG-161115V3.BIN the file not be encrypted >> Do Link Flash https://drive.google.com/open?id=0Bw...FFTZmJzcHZqeTg GOOD LUCK |
The Following 4 Users Say Thank You to gracy_elec For This Useful Post: |
03-27-2018, 16:50 | #11 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | Hello @sadeeq34772,this file already on support area download and post result Good Luck |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
06-12-2019, 10:52 | #15 (permalink) |
Freak Poster Join Date: Jun 2005 Location: My country is Kenya. Age: 39
Member: 153875 Status: Offline Thanks Meter: 35 | log with miracle MTK SF File: MT625A/6260 The File Information: UL251_T465_PCB01_GPRS_MT6260_S00.T465-UL251D1-AF-161213V9.BIN Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM11) Connecting to Phone,Wait.. Connected to Phone. CPU: MT6260_S0000 Ver: CB00 md:8000 Downloading Boot7 ... >>ERR21002.00 log with cm2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8BE237974814133EF7F83945AD02C8AA BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : F800 4300 1700 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xAA SOC Verification failed! Check cable, Battery, Connection! Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
