11-30-2007, 07:26 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: MOBILE WORLD
Member: 107267 Status: Offline Thanks Meter: 62 | TECNO T800 dead after flash but this time i flash TECNO T800 (File download from support) now phone is not startup (only side light blinking) i use rpl service but cant get any result Pls. help me ... now what i do..... |
11-30-2007, 13:59 | #3 (permalink) |
Member: 107267 Status: Offline Thanks Meter: 62 | This is LOG when i first time formate this phone Do you want to continue ? COM5 [VCP0] selected Device: Tecno T800 Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6225:8A03]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN ver. sw2: CBM10_2_E_V3 ffs offset/size: 00E00000/00200000 reading [eeprom[BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN]]... file saved: backup_eeprom[BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN]_20071127-211235.B0E.bin flash: 98004900000002:18E59F00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:AD6CAD00000000 Write Done Finished, time used: 233 sec Remove/Install battery now ! |
11-30-2007, 14:06 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! our flash file for this phone is for different hardware. you can see this by comparing version: yours: BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN support: CBM01_PCB01_GPRS_MT6226_S01.CBM04_070711_V60_En_Fr _Ar.B0M.bin you can see that MCUs are different. you must find good working phone with 6225 MCu and read out backup. we will update our suport area with needed file. in future always carefuly check if flash file is suitable for you phone. If any doubts- make full backup of your existing firmware for emergency case. |
12-04-2007, 16:50 | #6 (permalink) |
Member: 107267 Status: Offline Thanks Meter: 62 | hello sir. i have same (BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3.BIN ) phone, and i read full flash, Now what i do ? (give me mail address when i send this file) |
12-04-2007, 16:55 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | please, send "backup_flash..." files to [email protected] also pls send "backup_system_log..." files, it's important |
12-06-2007, 08:44 | #8 (permalink) |
Member: 107267 Status: Offline Thanks Meter: 62 | i send backup file and i get flash file from support area, Thank you INFINITY, now i flash my phone but cant get any result.....i flash by same version file but phone cant start up only blink side lite... what i do ???? Help me ... |
12-06-2007, 18:49 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use Tecno-T800_BIRD25_06B_PCB01_GPRS_MT6225_S00.CBM10_2_E_V3 _En_Fr_Ru_Ar file from support area and use latest ChineseMiracle. Make "format" after flashing. Post here flashing log. Don't forget to charge batery complately ! |
12-07-2007, 08:31 | #10 (permalink) |
Member: 107267 Status: Offline Thanks Meter: 62 | Yes Sir, i use this file and format after flashing but cant get result, but i have eprom backup of this phone (backup creat when i flash this phone first time) this backup write on phone (after flash above file)and now my phone is ON and work fine ............ Thank you for your co-opration... |
07-10-2008, 08:44 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Welcome Back J.A.F Age: 47
Member: 135200 Status: Offline Sonork: 100.1594691 Thanks Meter: 33 | please give me pinouts of tecno t800 12pin L12c cable please give me pinouts of tecno t800 12pin L12c cable i cannot detect pins with any finder and aslo i used the pins near the sim reader but still cannot work. |
The Following User Says Thank You to milankumardoshi For This Useful Post: |
07-10-2008, 11:53 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! t800 do not keep tx/rx in system connector- this is why pinfinder failed to find pinout. please check infinity pinout folder for file named "Tecno-T800.jpg" that will be correct pinout for your phone |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
