tecno t880 no signal on sim2 how can i fix this problem the phone does not indicate signal on sim 2 , i can make call , but i can't receive can i format second sim harware? |
hello! i would advice to make second MCU firmware full backup and make format FFS. for doing this you must assemble cable with second MCU pinout |
ignition for second mcu is pwr boton? because i get a error ..... and my phone start up when i put pwr boton |
this is my error : warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E221A2201:18E59F00000000 error: wrong erase first sector at 0x00600000 Finalization Fail Finished, time used: 17 sec Remove/Install battery now ! |
and when the phone start appears ''write psn'' |
hello! please next time post full log, not only that part that You think is important. also, what cable do you use? |
i use pin finder...... 9rx,10 tx for second mcu and 7rx,8tx for second mcu |
hello! and may i see FULL log with this error? |
