03-05-2009, 05:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Mexicali
Member: 372188 Status: Offline Thanks Meter: 57 | telcel me970 flash error module v1.63 Device: LG-ME970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME970_eeprom-static_20090304-200547.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME970_eeprom-static2_20090304-200547.B1E.bin loading data... data loaded imei: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ reading eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME970_eeprom-security_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090304-200549.B1E.bin reading eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ... file saved: C:\Program Files\InfinityBox\Pana01\LG-ME970_eeprom-complete_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ_20090304-200549.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Writing: Firmware repair write error [A0192000:0800]... error: write failed[A0000000] error: erase is not confirmed Write Failed Finished, time used: 37 sec Remove/Install battery now ! After the errors infinity box disconects and conects by itself. Any help please? |
03-05-2009, 23:52 | #9 (permalink) |
Member: 372188 Status: Offline Thanks Meter: 57 | Following: Check memory ... Check memory Done Write ... Writing: Firmware repair write error [A0192000:0800]... error: write failed[A0000000] error: erase is not confirmed Write Failed Finished, time used: 37 sec Remove/Install battery now ! Then infinity disconects and conects by itself... |
03-06-2009, 06:12 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you see the same error during flashing (eror always at the same flash chip address) this means that it's hardware fault (f.e. bad soldered or damaged flash chip). It is need to open phone and as a first step rehot/reball flash chip |
03-06-2009, 15:27 | #12 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | hi, flashing this version and you have good phone. firmware ---> ME970dP40FL-58-V10a_734-04_firmware-Movistar.B1M.bin eeprom --> ME970_repair_eeprom_complete_05.B1E.bin |
The Following User Says Thank You to cellcarcol For This Useful Post: |
03-06-2009, 16:24 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If he has the same log http://forum.gsmhosting.com/vbb/show...81&postcount=9 again and again it's not a problem with files or flash process but it's a hardware problem. |
03-06-2009, 17:02 | #14 (permalink) | |
Member: 372188 Status: Offline Thanks Meter: 57 | Quote:
03-06-2009, 22:13 | #15 (permalink) | |
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
the flash you indicate you prendera your phone. uses that. | |
N96 Weird Flashing error | javakiller | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 10-10-2010 11:55 |
1650 flash error | nilesh_patel717 | Nokia Hardware & Hardware Repair | 3 | 03-29-2010 14:03 |
s3650 from telcel , need flash file | layna | NSPRO | 3 | 01-20-2010 19:58 |
6300 telcel mexico unlocking error | tajinder | Nokia Base Band 5 ( BB-5 ) | 1 | 10-08-2008 19:13 |
LG ME970 Flash | Racionais | LG | 0 | 08-07-2007 15:05 |
