Old 01-28-2015, 18:21   #1 (permalink)
ecsike's Avatar
Member: 4597
Thanks Meter: 35
Telenor 2020 Unlock!?
Chinese Miracle II [RDA module] v 0.07
Start at : [2015/01/28 / 17:48:21]
Operation : Read FullFlash
======= Settings
Settings : SafeMode is Off [Fast]
Settings : Make IFF (MCU) file
Settings : Make Calibration file
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Init : 55555555
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4007
CPU_CN : RDA Micro CT , RDA8851L
==== FLASH
FL_VEN : 60C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Set : 8809 , 00400000
Use : 8809_00400000_usb.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Flush : 0400F000
Loader run
Boot Done!
Read Flash now ...
Read Ok, 4194304 bytes read
Verify file...
Target BbCpu : CT8851A
Target Flash : flsh_spi32m
Project Name : test_version
Project Info : dt102_3216
[BIN] Saved as : test_version_dt102_3216_CT8851A_flsh_spi32m.bin
Make FlashFiles
FATNV Check passed
FSCSC Check passed
CALIB Check passed
[IFF] File saved to : c:\InfinityBox\CM2RDA\Flash\IFF\test_version_dt102 _3216_CT8851A_flsh_spi32m.iff
[CAL] File saved to : c:\InfinityBox\CM2RDA\Flash\IFF\test_version_dt102 _3216_CT8851A_flsh_spi32m.ifc
Build done
Done
Elapsed: 00:00:50
Finish at : [2015/01/28 / 17:49:11]
Reconnect Power/Cable!
https://mega.co.nz/#!sloQETZY!5_IGnD...iUBfN7uBo9XCSg
Can you help mi how can unlock this!?
Old 01-29-2015, 08:10   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,182
Hello. No yet... It will be great get phone on hands to make something. Without it - it just a mess with trying and testing remotely.
Old 01-29-2015, 22:40   #3 (permalink)
Member: 2276517
Thanks Meter: 35
@ecsike
read file to unlocked phone and write to locked phone
after your phone is unlocked
Old 01-29-2015, 23:49   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,182
Originally Posted by togolais View Post
@ecsike
Great advise. Give us "UNLOCKED" file, for start. If can't - be smarter, keep silence and increase your post counter with real help.
Old 01-30-2015, 12:33   #5 (permalink)
ecsike's Avatar
Member: 4597
Thanks Meter: 35
I have modified little bit the readout file, I succeded to unlocked the phone. You don't have to use tick at flash writting at Factory Settings and Skip NV.
http://web.t-online.hu/dazexy/test_v..._by_ecsike.zip
Thxxx for your help!
The Following User Says Thank You to ecsike For This Useful Post:
Old 01-30-2015, 13:12   #6 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 56,118
I can provide you the patch the mcc mnc patch for free Just ask
Old 01-30-2015, 13:24   #7 (permalink)
Member: 15022
Sonork: 100.53452
Check is similar to one bellow
    if(!((memcmp(UpdatePlmn, "46000", 5) == 0) || (memcmp(UpdatePlmn, "46001", 5) == 0) || (memcmp(UpdatePlmn, "21601", 5) == 0)))
        if(gSPNIfo[simID].nSPNDisplayFlag == 1 && gSPNIfo[simID].nSPNameLen > 0)
            gSpnValid[simID] = 1;
            if(gSPNIfo[simID].nSpnName[0] > 0x7F )
                memcpy((S8*) gServProvderName[simID], gSPNIfo[simID].nSpnName + 1, gSPNIfo[simID].nSPNameLen - 1);
            else
                AnsiiToUnicodeString((S8*) gServProvderName[simID], (S8*)gSPNIfo[simID].nSpnName);
So can add now one fast patch unlock
Old 01-30-2015, 16:03   #8 (permalink)
Member: 15022
Sonork: 100.53452
Really Big Thanks , will try
1A 61 -> 65 00 . Need to make some pattern search to find the spot. Shouldn't be too difficult
Old 01-30-2015, 16:16   #9 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,182
Yes , looks like done , with SP Info reading
Thanks!
Old 01-31-2015, 09:57   #10 (permalink)
Member: 15022
Sonork: 100.53452
Some backups i had around. Let me know when is ready so i can try
https://www.mediafire.com/?4aa5dla7km7gyaa
http://www.mediafire.com/download/0i...or2020full.bin
Old 02-03-2015, 22:16   #11 (permalink)
bighiner's Avatar
Member: 679176
Sonork: 1585224
Thanks Meter: 118
and what flasher do i use to write this?
thx
i hope is not stupid quastion
Old 02-04-2015, 15:53   #12 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,459
thx
Cant Say About Flasher But U Can Use
Grate Infinity Cm 2
Page generated in 0.35153 seconds with 7 queries
