04-03-2016, 05:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | telenor easy 3g modle w2 help cannot read any info but only this ================================================== ======= Card found: S/N : 3F39398A , v0130 Chinese Miracle II [SPD module] v 1.16 Start at : [4/3/2016 / 1:22:57 AM] Operation : Read FullFlash [ v1.16 ] Connect Powered Off phone. Insert battery ( If not used VPP ) ==== Wait for phone... Reconnect Power/Cable! Finish at : [4/3/2016 / 1:22:57 AM] Start at : [4/3/2016 / 1:23:37 AM] Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 15 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [4/3/2016 / 1:23:44 AM] Start at : [4/3/2016 / 1:23:51 AM] Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! Finish at : [4/3/2016 / 1:24:38 AM] Start at : [4/3/2016 / 1:24:45 AM] Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! Finish at : [4/3/2016 / 1:24:56 AM] Start at : [4/3/2016 / 1:25:12 AM] Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Lost connection with Target! Boot failed! Reconnect Power/Cable! i try with all boot mode only have this info logs and set pic is here Phone Add For Sp Unlock Request.. Report Post |
